View Full Version : O2 injection...
smurf3642 01-29-2005, 06:40 AM I had a thought...
I want to stay away from NoS cuz of it's danger and illegilality...
But, since pure oxygen is highly flammable...would setting up an injection system using pure oxygen instead of NoS still get an increase in power??
just a thought...it'd be cheaper than NoS too...
Lendincash 01-29-2005, 08:55 AM Yea.........put some wings on, maybe you can fly away. :doh:
Lendincash 01-29-2005, 09:06 AM Heres the deal with N20, otherwise known as NOS(which is actually a manufacturer of Nitrous Oxide). N2O is not a flamable gas in its independent state. Our atmosphere contains roughly 23% oxygen; respectivly, N20 contains about 36% oxygen. N2O is a much more dense gas than our atmosphere at a given temperature/pressure, allowing for this greater amount of oxygen. So here is what I am getting at; instead of force feeding your engine air(turbo/supercharger) which increases the pressure (boost) of which the air is used in the combustion chamber, you can give it a shot of nitrous(many ways avaliable) causing a similar reaction.
Pure oxygen would simply cause such a powerful explosion, your motor would not be able to control it. That is why N2O is a safer bet.
Sunday morning, I will run to the neighbors house and gank their O2 tank, jimmy rig it, and drive the car. I will take pictures of what is left!!
Lendincash 01-29-2005, 09:07 AM One more thing, N2O is not illegal and not dangerous to your car when used correctly. Now inhaling "nitrous" is a completly different topic.
Somnambulated 01-29-2005, 09:10 AM I had a thought...
Yes. Pure Oxygen would be much safer, considering it is highly flammable. :eyebrow:
Uhm, anyway. The easiest way to get busted for having Nitrous in your car--even if the bottles are nearly empty, and not connected in any way to your engine--is for transporting Hazardous Materials. Pure oxygen is one of these. If you don't have a Haz-Mat certification on your license, I wouldn't suggest putting either in your trunk anytime soon.
Lendincash 01-29-2005, 09:15 AM :rofl:
Safer it is, I'm glad we agree!!
Mediocre_Generica 01-29-2005, 11:09 AM I've never heard about anyone getting in trouble for having nitrous in their car...
Then again I live in Michigan and you could probably run an open header without getting in trouble.
Hudnut 01-29-2005, 12:29 PM I was playing around with an old homelite motor and a cutting torch a year or so ago. when I blew pure 02 in the carb it would just stall. If I put the choke on (more fuel) and gave it some 02 the thing ran like a mutha.. untill it exploded. sure 02 will make a motor run hard. but you have to manage a/f and all that. that's why there is n20, it's basicly a carrier for the oxygen.
toyota_scion_tc 01-29-2005, 01:50 PM If you did something like that you need to be extreamly carefull. IT will cause you to run lean and when you run lean the gases burn hotter. It might acutally cause you to burn a hole in your piston.
SCI_TC_GUY 01-29-2005, 02:10 PM yeah....the way n2o actually works is the same concept as a cold air induction.....the n20 comes from the bottle at wicked cold temps....and as we all know...colder air is more oxygen dense. so when you shoot your n2o into the air intake, you get a concentration of oxygen at a higher ratio to the other gasses inthe air therefore causing more burn. If you ran a very small amount of n2o constantly or variable with engine RPM's then you'd get the same product as a cold air intake system.
SCI_TC_GUY 01-29-2005, 04:11 PM soooo....the verdict is..*drumroll*.........
to put a direct shot of oxygen into your car would be about as smart as using a can of raw ether for an ashtray.....
smurf3642 01-29-2005, 05:37 PM AHHHHH...
I learned something today...
:clap:
Harman 01-29-2005, 06:16 PM I'd say if you have a bottle of O2 in your car is much more dangerous than having a bottle of N2O. Pure O2 with enough fuel will cause such violence combustion, if not manage properly, will easily fried your engine like a piece of meat. Let's not forget the purpose of Nos is to produce more O2 for internal combustion. In contrast, N2O is much safer because the O2 content is lower and thus easier to manage and control the dosage. Imagine what may have if one has accident and the oxygen bottle is punctured? If Nos is dangerous in this situation, pure O2 will make it worse.
PS. Oxygen is NON-FLAMMABLE, it will facilitate combustion, that's all.
Lendincash 01-29-2005, 06:41 PM I'm glad that we all have sense not to feed pure O2 to our motors this weekend; I feel like we have all saved a Scion owner from making a devastating mistake. :clap:
smurf3642 01-29-2005, 07:40 PM What if you inject O2 into the engine at very low dosages??
staying in the safe zone, while increasing the power of combustion??
let's not forget, the reason I'm asking, is because I don't this...
Number2 12-18-2007, 06:54 PM You could use an oxygen tank for your paintball marker. Waaay better than CO2
SLIVER007 12-21-2007, 08:22 PM has anyone checked into C02, Was thinking about getting soem Co2 sprayers for my intercooler?
