Need help with Code P0441
Old Aug 12, 2009 | 12:22 AM
goodguy889's Avatar
Default Need help with Code P0441
hey whats up well i was driving home today and not boosting and my CEL comes on, well i check it and its a "P0441 Evaporative emission control system incorrect purge flow".
my question is what the does thta mean and how do i fix it. my car is an 08 and its Supercharged. i have the 9.5 pulley, header, intake. please help lol i hate my car.
Old Aug 12, 2009 | 12:23 AM
goodguy889's Avatar
also could this explain y i would be leaning out a little?
Old Aug 12, 2009 | 01:33 AM
mastertech86's Avatar
check ur gas cap
Old Aug 12, 2009 | 05:22 AM
youngflyer's Avatar
wouldnt that be "large leak" if it was the gas cap?
Old Aug 12, 2009 | 05:41 AM
krazyjvilled's Avatar
can someone tell me if you can run a cold air intake or short ram with a TRD supercharger? dont mean to hijack... just need to know thx
Old Aug 12, 2009 | 05:48 AM
N0AuTHoRiTy's Avatar
If it was the gas cap, the code would be "small leak".
A code P0441 could mean one or more of the following has happened:
1) Bad vacuum switch
2) Broken or damaged EVAP line or canister
3) Open in PCM purge command circuit
4) Open or short in Voltage feed circuit to Purge Solenoid
5) Faulty purge solenoid
6) Restriction in EVAP solenoid, line or canister
7) Corrosion or resistance in purge connector
Bad PCM
Usually, for a code like this, it would just be the Evap Canister or Purge Solenoid.
Old Aug 12, 2009 | 06:00 AM
Boi's Avatar
Boi
Bad PCM
had this same problem for half a year now. this check list is the best info ive gotten scine then, thx ill look into it.
Old Aug 12, 2009 | 01:14 PM
CarbonXe's Avatar
I had this code on my 05 tC, it was the gas cap.
Old Aug 12, 2009 | 04:54 PM
trd07tc's Avatar
x2
Old Aug 13, 2009 | 01:00 AM
goodguy889's Avatar
yeah it was a pinched line but yeah still kinda running lean and i think its my air filter (i hope) but other then that i have no clue
Old Aug 13, 2009 | 01:09 AM
BC_Scion_LA's Avatar
matt do you wanna sell our cars together one day we can make it a date! LMAO (no homo) by the way mines still not running from lafayette hah.
Old Aug 14, 2009 | 12:45 AM
goodguy889's Avatar
damn when u ge all ur parts?
Old Dec 21, 2009 | 09:06 PM
tCjosh's Avatar
dont mean to bump an old thread (IM NOT A NOOB!!!) but which line was piched that threw this code for you??? im throwing the same code and have checked the lines and they all seem fine...
Old Dec 22, 2009 | 09:22 PM
goodguy889's Avatar
for me it was a line that purges the gas tank and pinched.
Old Dec 22, 2009 | 09:53 PM
tCjosh's Avatar
you fixed it yourself or took it to a shop/dealer to get it fixed??? where exactly was the line? gas tank area under the car?
Old Dec 23, 2009 | 05:45 AM
goodguy889's Avatar
i did it myself. its in the engine bay. kinda by the throttle body, its a little box that has a couple hoses connected to it. u can follow ur vac. line to find it. here is a pic of it. only pic i could find that has it.
Old Dec 24, 2009 | 02:16 AM
tCjosh's Avatar
oh ok i know what vac lines those are now... they were fine on my car... the CEL light seemed to go away when i re-tightened my gas cap. i guess i didnt tighten it up the last time i filled up, but thanks for the help!
Old Dec 24, 2009 | 02:25 AM
Originally Posted by mastertech86
check ur gas cap
That_Kid_Ju
Sep 30, 2015 10:05 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
wayneside
Regional - Southeast
Sep 23, 2015 10:42 AM
wayneside
Regional - Pacific Northwest
Sep 23, 2015 10:29 AM
Gigs
Sep 15, 2015 03:54 AM
