Time to finally do my clutch.
Old Aug 15, 2009 | 10:23 PM
Syldrin's Avatar
Default Time to finally do my clutch.
So today i purchased an ACT street disc for the scion tC. Which i must say i got a killer deal on. i picked it up for 400 bucks at a local shop here. I also got some redline MT-90 gear oil. now my owners manual is in my car, and my car happens to be at my friends house where we are doing the clutch. can i get somone to confirm for me that 75W90 is the correct weight for our trannies. i did some google searching and well i trust the folks on here more then the other answers i found.
Assuming weather holds up i should be putting miles on my clutch tomorrow evening.
pics of the destroyed clutch tomorrow or monday.
Again i want to thank the guys over at dezod for helping me figure this problem out over the phone.
Old Aug 15, 2009 | 10:31 PM
ack154's Avatar
Redline MT90 is the stuff.
Old Aug 15, 2009 | 10:54 PM
Crush Automotive Customs's Avatar
75w90 is what your looking for....redline mt90 is 75w90 if im not mistaken...
I know a few peeps are going to come on here saying that mt90 sucks and to use something els or another brand sucks and to go to something els, i just want to say that make sure all of the old gear oil is properly drained (shouldnt be a problem for ya) and that its filled to proper capacity.
Old Aug 15, 2009 | 10:57 PM
SoFloTC's Avatar
redline mt90 ftw.
Old Aug 15, 2009 | 11:09 PM
Syldrin's Avatar
wow. somone want to tell me how to remove images from a post. this new SL layout is kickin my A
Edit - apparently its as simple as pressing the delete key.
Old Aug 15, 2009 | 11:35 PM
Prototype_xB's Avatar
looks like ur all good to go
Syldrin's Avatar
i still cant believe my stock clutch held up to, learning to drive a stick on this car and over a year of being boosted.
Old Aug 15, 2009 | 11:44 PM
Syldrin's Avatar
Flywheel bolts are 12lbs-ft right?
Old Aug 16, 2009 | 01:21 AM
that doesnt sound right to me...i think its much higher but id have to check.
Old Aug 16, 2009 | 01:26 AM
my06tc's Avatar
i use to use redline after the OEM but after 3000 miles my gears started to grind no it wasnt me...im using eneos and problems went away and so far so good....redline is not bad but ive heard from others had similar issues....but when you first put it in ill feel smooth then after awhile youll see if it happens..yea i drained my oil completely and put the right amount in...
Old Aug 16, 2009 | 01:34 AM
clutch cover= 14ft-lbs
fly wheel to crank= 96ft-lbs
find it here as well...https://www.scionlife.com/tech/manual/?manual=tc05_0123
Old Aug 16, 2009 | 01:51 AM
Syldrin's Avatar
thanks crush.
Old Aug 16, 2009 | 02:56 AM
CSUnited14's Avatar
Link please sir.. i might be redoing mine eventually again.. yes i have this grinding issue as well doesnt want to go in gear at times as well... no its not driver issue i have been driving stick for 50k miles :D
Edit: yes i have mt90 in right now
Old Aug 16, 2009 | 05:16 AM
Syldrin's Avatar
gear oil is supposed to be changed every 30K i dont care what redline says. it all breaks down they may say it lasts longer but it wont be much.
Old Aug 16, 2009 | 11:07 AM
thanks crush.
your welcome
Old Aug 16, 2009 | 06:59 PM
Syldrin's Avatar
anyone have any last minute advice about doing a clutch? i've only ever done one and i had a lift and a bunch of other tools i wont have today. so if anyone has any suggestions on a driveway clutch drop your advice here please!
Old Aug 16, 2009 | 07:21 PM
Cwatz5219's Avatar
Dude go with Eneos Gear oil 75w90.
I originally had Redline mt90 in my tranny but after 2k miles i noticed that my gears started to get stuck and that it was hard to shift sometimes. I changed to eneos and haven't had not one problem. I've been going a little over 3k miles and not once has my gears ever gotten stuck.
Old Aug 16, 2009 | 07:36 PM
Syldrin's Avatar
i run eneos motor oil and i love the stuff but its to late now if i have problems with the MT90 i'll just replace it. its sunday and nothing i can do about it now.
Old Aug 16, 2009 | 08:16 PM
ValenciaS's Avatar
Yeah thats insane, I been boosted for about 5,000 miles and my stock clutch held up fine, its just now im realizing its starting to slip in boost, but holds up good on normal driving. Need to be replaced soon
Old Aug 16, 2009 | 08:58 PM
Syldrin's Avatar
omfgiamsoboredandwanttogetthisstarted.
