Car won't lock or unlock with Factory Keys? wtf?!?! input needed
Old Aug 16, 2009 | 03:13 AM
rosedaleny806's Avatar
Default Car won't lock or unlock with Factory Keys? wtf?!?! input needed
Hey every1, so yeah my car won't lock or unlock with my factory key? idk wtf is up with it. was working fine 3 days ago well I thought it was then I noticed hey my blinkers aren't blinking when I unlocked the door and then realized it wasn't working.
any1 knows wat it can be? I thought at first it was the battery on the key but the red light still blinks when I press any button. does any1 know what else it can be? any input/information welcome its getting really annoying locking the door with the keyhole.
another thing, doesn't the car lock on its own after a certain amount of time? like when u tuen the car off take the keys out and close the door, doesn't it lock after awhile? cause its not doing that anymore.
HELP!!!
Old Aug 16, 2009 | 03:21 AM
Joyride's Avatar
smack the key or leave it be for a bit.
iT happened to me once and i was wtfing as well. But the next day it was fine.
Old Aug 16, 2009 | 03:27 AM
LOL haha ok I'm definatly gonna try hitting it. it happened 3 days ago and still nothing its ____in me off lol
Old Aug 16, 2009 | 03:37 AM
getaforknjob's Avatar
I would say for some reason it seems like it needs to be reprogrammed.
I have no idea how to do that though.
But yeah..hitting things always is a good fix.
Old Aug 16, 2009 | 03:43 AM
pioneer1976's Avatar
sounds like its lost its programming, i believe the dealer is the only way to do it.
Also no our cars dont lock automatically. the only way it locks automatically is when the car is locked and you use the remote to unlock, and if you dont open the door after a little while then it will relock the doors for you..
Old Aug 16, 2009 | 03:45 AM
Tomas's Avatar
Admin Emeritus
Have you thought to check the battery in the remote and the fuses in the car?
Old Aug 16, 2009 | 04:00 AM
I thought it was the battery in the remote but the led on the remote still flashes when I press the buttons? I thought maybe the remote needs to be reprogrammed but idk? and I actually haven't though bout the fuses. does any1 happen to know which fuse it would be??
Old Aug 16, 2009 | 04:01 AM
and does any1 know how to reprogram it? or is it jus at the dealer? (which I doubt)
Old Aug 16, 2009 | 04:34 AM
my06tc's Avatar
its not any fuses or anything like that..it has to be reprogrammed the only person that can do that is the dealer....
Old Aug 16, 2009 | 04:46 AM
draxcaliber's Avatar
did you try your spare key? if it was just one key failing to work the keyless entry, i would guess it was the battery, even if that little LED does light up, it probably has enough power to light up the LED, but not enough strength to broadcast to the car. so if your spare key works, then it would be the battery in the other key being dead.
if both keys aren't working, i would guess the problem is with the car itself, either it isn't receiving the signal, or there is a problem with it recognizing they key. assuming there isn't a fuse or something out.
Old Aug 16, 2009 | 07:45 AM
Air2TheThrown's Avatar
That happened to me once. I thought I needed to change the key battery but that didn't solve it. I just reprogrammed the key and it worked again.
Old Aug 16, 2009 | 03:21 PM
t8legos's Avatar
if you have the scion security system i believe it automaticaly locks after 30 seconds only if you press the unlock button and then do not open a door within 30 sec. thats how mine works anyway and im fairly sure thats what the manual says. gl
Old Aug 16, 2009 | 03:47 PM
drax I don't have a spare key to the car I lost it years ago while I was moving and never was able to find it, I'm thinkin it was the battery has enough to light the led how u say but not enough to go threw to the car and if I leave the key alone for awhile and press the button the LED looks a lot brighter but when I continue pressing it it becomes very faint and dull. it might be that. airtothethrown how did u reprogram the key? is it really a dealership thing? and t8legos I don't have an alarm on the car its jus the factory keyless entry but I remember that my doors use to lock after awhile when I pressed the unlock button. now its not doin that at all. ugh!
Old Aug 17, 2009 | 01:19 AM
kmx22's Avatar
well, does the car start all? if you can start the car with ur key, you don't have to bring it to the dealer, just do it urself.
by unplugging the battery, you probably reset the key too. or you just pressed the reset button on the key somehow.
try these steps...
1. Start with the following conditions: You are in the drivers seat-
a. Key is out of the ignition
b. Driver door is open (all other doors closed)
c. Driver door is unlocked (other doors don't matter)
2. Insert and remove the key from the ignition twice within 5 seconds
3. Close and open the drivers door twice within 40 seconds
4. Insert the key into the ignition and remove it.
5. Close and open the drivers door twice within 40 seconds
6. Insert the key into the ignition
7. Close the door
8. Turn the key in the ignition on and then off.
9. Remove the key from the ignition
10. The power locks should automatically cycle once to indicate that you have successfully entered program mode.
11. Within 40 seconds of the entering program mode:
a. Press both transmitter lock and unlock buttons SIMULTANEOUSLY for a duration of from 1 to 1.5 seconds.
b. Within 3 seconds, press the transmitter lock button for more than 1 second and release.
c. If the transmitter has been successfully programmed, the power locks will automatically cycle once. If they cycle twice, the remote has not been accepted.
d. If multiple remotes are to be programmed, repeat steps A-C
12. Open drivers door
Old Aug 17, 2009 | 02:42 AM
LOL r u serious? all that? haha I'm gonna try it in the morning thanx bro, hopefully it works hahaha that's alott
Old Aug 17, 2009 | 04:30 AM
Yeah I think that's what I did with my car too. It was embarrassing to do, kind of like doing the hokie pokie for your car.
Old Aug 17, 2009 | 11:36 AM
haha ok I'm trying it in alittle bit wish me luck
Old Aug 17, 2009 | 10:57 PM
KMX ur the man it worked! great stuff, i was kinda iffy on going to the dealewr but it worked thanx alot bro!
PLZ LOCK/DELETE or hell Even sticky if there isnt any to reprogram a key
Old Mar 21, 2013 | 03:00 PM
tCmla's Avatar
Thank goodness I found this thread now time to do the ritual with my car.
Jordly221
Feb 13, 2019 05:29 PM
lunchbx05
Dec 29, 2014 07:53 PM
rancur3p1c
Dec 19, 2014 04:30 PM
Kiwibox
Dec 15, 2014 09:46 PM
XB_2
Nov 23, 2014 02:48 PM
