2AZFE block question
Old Aug 17, 2009 | 03:45 AM
naptownballer's Avatar
Default 2AZFE block question
will all blocks work on all year tc's?
Old Aug 17, 2009 | 04:17 AM
Prototype_xB's Avatar
to my knowlege, yes. The 07+'s have only higher compression pistons and oil squirters and a different stock exhaust manifold design
Old Aug 17, 2009 | 05:01 AM
XIEmperorIX's Avatar
That and the MAF sensor is different as well.
Old Aug 17, 2009 | 05:06 AM
BlackKnight's Avatar
Music City Scions
Oil passages and coolant passages are a little different on the 07+ as well. If you use your OEM harness and sensors there shouldn't be an issue putting in a 07+ block in a 05-06 tC and such. I am using a 07 in my build.
Old Aug 17, 2009 | 09:50 AM
Rydrdg's Avatar
Will you pass inspection when you put in a new built block, will it throw of codes?
Old Aug 17, 2009 | 10:19 AM
Music City Scions
It will only throw codes if there is an issue. Most states you will be fine but if they check the vin on the engine then they may not pass you. The engine isn't going to physically run different unless there is an issue with a bad sensor, mechanical problem internally and/or it wasn't installed properly.
Old Aug 21, 2009 | 05:10 AM
gingles's Avatar
naptown is probably the worst scionlifer on the forums. i sold my block to deez and nap has been calling him telling him all kinds of crap. saying that it wont work yada yada. he has called me numerous times AFTER i told him the block was sold. he told me to sell the block to him anyway and refund deez's money. i just wanted people to be aware of the shady person whos name is naptownballer.
Old Aug 23, 2009 | 05:37 AM
fail
Old Aug 24, 2009 | 05:41 AM
jar2709's Avatar
Dam gingles good look out
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
xBassist
9
Jan 21, 2004 07:34 PM
