trd lowerinng springs
Old Aug 22, 2009 | 02:18 PM
vato83's Avatar
Default trd lowerinng springs
hey guys i got a ?, i think my dealer dont want to admit i got a bad set of trd springs , i got my 09 tc lowered with trd springs eveything looks ok except my rear drivers side wheel looks like its about 1/2'' lower and tilted in a bit more than my passenger side had it checked alignment was ok so what else can it be....... never been in a accident ..... the dealer lowered it before i picked it up... i got 19'' wheels with 40 offset...... here are my numbers now ;
left front~ camber -0.2 / caster 3.5 / toe 0.00
right front~ camber -0.8 / caster 3.6 / toe 0.01
left rear~ camber -1.3 / toe 0.13
right rear~ camber -1.4 / toe 0.15
front...total toe 0.01
steer ahead 0.00
rear....total toe 0.28
thrust angel -0.01
Old Aug 22, 2009 | 03:28 PM
vato83's Avatar
anyone?
Old Aug 22, 2009 | 04:15 PM
engifineer's Avatar
For the alignment settings.... it just needs an alignment, which it should after the springs settle anyways
Old Aug 22, 2009 | 04:39 PM
vato83's Avatar
im sure the springs should of settled by know i got it lowered back in 02-09 then i went back for alignment on 06-09 after i got new tires and it still looks odd
Old Aug 22, 2009 | 05:01 PM
vato83's Avatar
so does my alignment look ok or should i get it done again
Old Aug 23, 2009 | 06:20 PM
engifineer's Avatar
Your camber is near even for the rear looking at the settings you posted (didnt even read them closely previously.. ). And that amount of negative toe is just fine. It is actually better handling wise to have more camber up front, but from the aspect of "normal" driving and tire wear you look fine.
Caster looks about normal, mine comes in at 3.6
Front toe is fine.
Rear toe looks fine.
So alignment settings actually look fine. Are you sure the springs are installed correctly? And have you actually leveled the car and measured from the ground to the fender to see if it is actually off?
Old Aug 24, 2009 | 02:18 AM
vato83's Avatar
hey thanx for your reply... yeah i did measure on a level surface and im about a 1/2'' higher on the rear passenger side
well i took it to firestone this morning and got that lifetime alignment so everything is normal except left rear camber is -1.7 and my right rear is -1.0 so the tech told me he would give me a call monday afternoon to see if he could find this part (forgot) for me. whatever the part is im sure theyre gonna rape me, so as soon as i find out ill let you know maybe ill be able to get it cheaper somewhere else
Old Aug 24, 2009 | 02:56 PM
Sparks_Scion_TRD_Parts's Avatar
The install was not done correctly. The TC has the hardest install to do due to the rear springs. I would take it back to the dealership you got the install done at and tell them to recheck everything they did on the install. They may just have to tighten down one bolt to allign everything.
Tim
DJ_FroZone
25
May 30, 2019 07:17 PM
airmankevin1
Feb 14, 2018 01:23 PM
Scion0814
Scion xB 2nd-Gen Wheel & Tire
Feb 12, 2015 01:41 AM
mark13018
Feb 6, 2015 08:57 AM
757_BRDFLY
Jan 9, 2015 12:29 PM
