removing center console in tC, how to do it?
Old Jan 31, 2005 | 12:31 AM
dctennis10's Avatar
Default removing center console in tC, how to do it?
I was thinking about adding cathodes to my tC and in order to draw the power from the cigarette lighter i have to take out the center console, does anyone know how to go about doing that?
Old Jan 31, 2005 | 12:58 AM
tekniq's Avatar
1) Unscrew your shift ****
2) Pull the lower portion of the plastic silver bezel consolish part back and lift up after it slides back. (disconnect the cig lighter before yanking too hard.
3) If you want to get the top part off pull straight back as well from the bottom portion of it and it should come off pretty easily.
It shouldn't take much force, just get your fingernails behind the plastic on the lower part and you're good to go.
Btw, this has been covered in other posts, search ;)
Old Jan 31, 2005 | 01:27 AM
dctennis10's Avatar
thanks man, sorry searching never seems to work for me
Old Jan 31, 2005 | 02:52 AM
tekniq's Avatar
Good deal, post some pics when you get it done, I'd like to see what ya came up with
Old Jan 31, 2005 | 04:20 AM
slikewhoa's Avatar
Post pics of how you ran the power too. I'm curious to see how you did it. Thanks.
Old Jan 31, 2005 | 08:27 PM
dctennis10's Avatar
sure, whenever i get the courage to rip apart my car ill post the pics lol
Old Feb 1, 2005 | 01:07 PM
Hudnut's Avatar
I found it much easier to get power from the fuse pannel. There are plenty of open slots in there. I just bought one of thoes "add a circuit" things. easy as pie.
Old Feb 1, 2005 | 01:22 PM
tbone587's Avatar
Hudnut, what are these add a circuit things u are talkin about and where can I get them for my xb. I want to add some cathoes in my car, but really dont want to cut wire in the cigarette adapter
Old Feb 1, 2005 | 02:27 PM
slikewhoa's Avatar
Same here...
Old Feb 1, 2005 | 07:23 PM
dctennis10's Avatar
i third that..where do you get them?
Old Feb 1, 2005 | 09:10 PM
slikewhoa's Avatar
I've seen pictures of them before, but I want more info on how to wire them and where to wire them.
I drive a tC if anyone can help.
Old Feb 1, 2005 | 10:34 PM
Hudnut's Avatar
You gotta get in the zone! autozone! It's in the isle with all the fuses and wiring stuff.
Old Feb 2, 2005 | 02:23 AM
dctennis10's Avatar
you got any pics hudnut?
Old Feb 2, 2005 | 12:05 PM
Hudnut's Avatar
no, it looks like a small block about 1/2" x 1/2" with 2 fuse slots, one set of blades, and one wire comming out of it. you just plug it into any fuse slot, it will still fuse the original circuit, and then use the wire to power the positive of your accessory. I grounded to a brake peadel bolt.
wiltonhall
Jun 23, 2025 10:09 PM
GrumpyCat
Feb 10, 2015 02:52 AM
DerekMarq
Jan 27, 2015 02:38 PM
randode
44
Jun 29, 2004 04:19 PM
Opr8r
Nov 3, 2003 03:34 PM
