View Full Version : Will this void my warranty???
Macthias
01-31-2005, 01:00 AM
I was thinking about hard wiring my radar detector using one of the fuses under the dash. The radar detector hard wire set up has its own fuse and a grounding cable. I was wondering if this could void my warranty? Thanks for your help
Macthias
hotbox05
01-31-2005, 01:16 AM
everything can void your warranty , just dont cut into a wire , use a fuse spliting thing .
duey
01-31-2005, 01:19 AM
you could just extend the cigarette plug down into the OEM socket get a splitter and plug it in, then tuck the socket and plug somewhere where its not visable.
Macthias
01-31-2005, 01:52 AM
no wires would be cut. I actually had this in my old car and just wrapped the wire around one side of the fuse and pushed it back into place.
duey
01-31-2005, 01:56 AM
u could do that, but just to be on the safe side i'd remove it before going to the dealer.
btw: they make these "fuse adapter" things that you can connect a spade connector to. That could also be used.
erichlf
01-31-2005, 04:18 PM
They have to honor your waranty as long as what ever mods you have done did not cause the problem. That is the law.
Joehnn
01-31-2005, 04:29 PM
This sounds like the best method. Just put orignal fuse in if you go for electrical warranty work.
1radtoy
01-31-2005, 04:40 PM
it shouldnt
