big 3 [help]
Old Aug 26, 2009 | 09:44 PM
Simplylibet's Avatar
Default big 3 [help]
is the big three the same thing as this?
Old Aug 26, 2009 | 11:21 PM
mattieg's Avatar
No the big three is a little different. The big three uses much bigger wire, up to zero gauge.
Definition: the "Big Three" upgrade means improving the current capacity of three cables: 1) alternator positive to battery positive, 2) battery negative to chassis, and 3) engine ground to chassis. Some people replace the factory wiring; others add additional cables to the factory wiring. This instruction is to add cables to existing OEM wiring.
Old Aug 26, 2009 | 11:46 PM
IH8ONYU's Avatar
its good to do both the "big 3" upgrade, and to also do an "uber grounding" kit.
you can use the same size wire for both the "Big 3" and the "Grounding kit" , i prefer 0 gauge... you can order on line, or maybe get lucky and find an electronics store that sells it by the foot or yard, just dont get confused if you use the same color cable for your positve upgrade (Big 3) and your negative upgrade (Uber Grounding). I used wire loom on my grounding wires, and wrapped black tape around the ends of the wire shielding, so if by some strange reason, someone other then me were to work on it, they would be "hopefully" less confused by all the extra wires.
Old Aug 27, 2009 | 12:03 AM
GammaTNT's Avatar
http://www.youtube.com/watch?v=SL-9o5kSgv4
i didn't do it to my tc yet. Might do it in the future.
Old Aug 27, 2009 | 06:37 AM
thankyou gamma that was somewaht helpful !
Old Sep 4, 2009 | 08:28 PM
GammaTNT's Avatar
Where can i buy 0 gauge wire cheap? i think the tc need about 5 to 6 feet.
Old Sep 4, 2009 | 08:57 PM
Hix's Avatar
Hix
Where do we ground the engine? I was having trouble finding a free bolt near the battery. Ended up doing the head and the hanger bolt for the stock exhaust.
Old Sep 4, 2009 | 09:23 PM
Nightbeat's Avatar
Your best bet is to make friends with a local audio shop, because they usually will sell it to you by the ft or finding an industiral electronics store.
Old Sep 4, 2009 | 11:48 PM
Hix's Avatar
Hix
Well I just did the 'Big 3' on my car. One thing I can say definitively is that I have the worst luck, and I fail at installs. It does seem to make a difference in idle and my trans shifts really firm... With my valve body upgrade it is actually a bit too firm and the car jerks like a truck. Throttle response is noticeable. I think I had a bad ground to begin with though because I have a very very VERY loud whine in my radio and now its gone. Prolly got messed up when I put my kit on.
I am probably the only person in existence who damn near lost a thumb during a simple wire replacement. That is blood on the ground...
Old Sep 5, 2009 | 12:25 AM
mattieg's Avatar
ummm what the hell did you do?
Old Sep 5, 2009 | 01:32 AM
Hix's Avatar
Hix
When I was crimping a wire I had my thumb where the stripper part is. Pretty much removed my thumb print. A little super glue and you can't even tell I cut myself. Good thing I have a hefty supply of Vicodine. Ended up taking me 7 hours to do a grounding kit...
Old Sep 5, 2009 | 07:14 AM
could you please take pictures of where each wire starts and goes from?
im like retarded and cant figure them out
Old Sep 5, 2009 | 04:17 PM
Hix's Avatar
Hix
I only did 4 wires. Engine (the exhaust hanger bolt under the bracket) Transmission (used an unused tapped bolt hole and a bolt from my tool box) body (Drilled a hole in the frame and sanded the paint off) and alternator wire. Make sure you leave the OEM wires attached and just use these as additions to that. I guess you could pretty much use any place away from a sensor. There seems to be quite a few tapped and unused bolt holes on the block you just need to find a bolt to fit inside. Google 'Big 3' for Scion there are quite a few DIY videos.
Old Sep 5, 2009 | 04:58 PM
mattieg's Avatar
Take a pic of your thumb lol.
Old Sep 8, 2009 | 12:38 AM
highvoltage1's Avatar
http://www.knukonceptz.com/ usually good deals on wire there!
yupinmytC
22
Jul 27, 2024 07:08 PM
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
neneago
Oct 27, 2015 04:47 PM
Blunderbuss
Oct 8, 2015 04:56 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
