Block Balance?? Engine Build 2azfe
Old Aug 29, 2009 | 12:08 AM
johnhawkins's Avatar
Default Block Balance?? Engine Build 2azfe
When installing Weisco pistons, K-1 Rods,ACL bearings, and Balance Shaft Delete....you DO have to get the block balanced correct?? Can you "adjust" the oil clearance when installing new bearings? Also any insight on oil clearance and adjustment for ACL bearings would be greatly appreciated.
Old Aug 29, 2009 | 12:29 AM
Windu's Avatar
Not the block. The rotating assembly. And balance shafts dont have anything to do with it. If your gonna get it balanced, take the crank, rods, pistons, pins, locks, rings, rod bearings, flywheel with bolts, clutch pressure plate with bolts, crank timing gear, and pulley or damper with bolt.
tom0613
Mar 7, 2015 05:59 PM
tcer904
Feb 25, 2015 08:12 PM
carid
Feb 12, 2015 11:54 AM
pro710
Dec 29, 2014 06:52 PM
