EFI fuse blown???
Old Aug 30, 2009 | 06:36 AM
skakemokid's Avatar
Default EFI fuse blown???
So, Long story short...
i was on my way to work today and my car died on me... Luckily i was really close to home when it happened so i pushed it home... I get home and try to start the car,
It turns over and over and over but wont start.. I checked my Scan Gauge and its not connecting. then hook up another OBD2 Reader and it says no link.
In my head I'm thinking something happen to the ECU or OBD2. I check the fuses and the EFI one is busted. I replace it and the car starts.
ok now to the question
Why did it blow? has this happened to anyone here? what causes this to blow?
ok well three ?'s..
Any input would be really helpful.. and really appreciated...
-Jay
___
Old Aug 30, 2009 | 08:58 PM
ricexizxgood's Avatar
I have had the same problem before and this happened (at least for me) b/c there was a short somewhere. For me the problem was that my head shield from my headers came loose and it was resting on somewhere else instead.
Old Sep 2, 2009 | 08:37 AM
skakemokid's Avatar
thanks alot man.. i found the prob..
Old Sep 25, 2009 | 10:37 PM
3min3m2's Avatar
What was the problem. I have the exact same thing going on, and i guess i am missing something so i would REALLY like to know this...
Old Sep 26, 2009 | 06:06 AM
skakemokid's Avatar
well for that guy it was a loose wire on his header. for me.. it was a loose wire i had for my fuel pump. i taped it instead of insulating it and it touched the chasis and made a short.
Have you installed anything recently ?
Old Sep 27, 2009 | 03:35 PM
3min3m2's Avatar
last two things were header and plugs. I changed the plugs back when i had this problem initially, seemed to solve it. Now it has reared its rather ugly head again.
I guess its time to check for shorts...
Old Sep 27, 2009 | 08:45 PM
3min3m2's Avatar
Default Found it. Oxygen Sensor on S Pipe was hitting a bracket under there.
Removed my anti-foulers, taped it up. Seems good to go so far.
____
Old Sep 28, 2009 | 02:26 AM
skakemokid's Avatar
Found it. Oxygen Sensor on S Pipe was hitting a bracket under there. Removed my anti-foulers, taped it up ,seems good to go so far.
glad its all fixed man..
TrueSlide
May 22, 2007 11:17 AM
philip
11
Apr 24, 2007 01:22 PM
philip
Apr 11, 2007 04:32 PM
JINeration
Regional - Lonestar
Jul 29, 2006 05:11 AM
HBScionBb
Jan 16, 2006 03:25 AM
