ScionGunner
01-31-2005, 09:43 PM
anyone ever thnk there car is melting i keep smelling burning plastic i thought i might have ran over a shopping bag but no and its not a wire smell ether
View Full Version : burning plastic? ScionGunner 01-31-2005, 09:43 PM anyone ever thnk there car is melting i keep smelling burning plastic i thought i might have ran over a shopping bag but no and its not a wire smell ether manejounxa 01-31-2005, 09:50 PM I get that burning smell also.so I guess im not alone. ScionGunner 01-31-2005, 09:52 PM yeah mine is after a long drive it smells just like burning plastic bags i wonder if its the intake it is plastic bolted to a hot metal block PandaIst 01-31-2005, 10:01 PM Hmmmm.....I don't think i've had that problem with my xA. I'll keep that it mind though next time I drive to see if i will smell that burn. 01-31-2005, 10:06 PM Have a manual? If you like using the clutch method to hold your car on hills, the clutch can get hot from the friction and create a burning smell. waynephinney 01-31-2005, 11:46 PM I used to use the clutch method in my driving, then I stopped. There's two things. You'll wear out the clutch faster, and in the case of gear braking, you'll wear on your engine faster. When I was a teen, someone told me that it wouldn't hurt the engine since it's used to that sort of thing, and I wouldn't wear on my brakes so much. Well guess which one is cheaper to replace when you destroy it? That's right, the brakes. Brakes are cheaper than a clutch too(assuming you just need new pads), so there you go. Derk-xB 02-04-2005, 01:46 AM I haven't smelled it in a few days. I smelled it on both xBs I testdrove, too. I attributed it to something being new... dunno for sure. jct 02-04-2005, 03:33 AM it might be your burning your new car smell away :silly: Distracted_Thinker 02-04-2005, 03:36 AM Nope not your clutch because in that case you wouldnt get it on long trips unless you get stuck in traffic. I think it just cause I rpm's are so high on regular driving so our engine heats up alot more than others. My rpms are around 3500 when im going 65 or 70. cseika 02-04-2005, 11:05 AM check to see if you may have accidentally dripped oil somewhere in the engine compartment where it can get hot, such as the exhaust manifold, etc.... I had the same problem on my Eclipse, turned out that when I pour engine oil, a little dripped on to my manifold and dried. So everytime it heats up i get that burning smell! Derk-xB 02-05-2005, 05:19 PM it seems to come from the back. I don't smell anything when I'm at the front of the car. :eyebrow: adorable 02-05-2005, 08:24 PM If it's the first hundred(s) of miles, could be just the usual break-in - oils, lubes, etc, just burning off. But if it's really strong smelling, or if it continues, I'd have the car looked at. Here, the 'new' car exhaust didn't last beyond a hundred miles or so, and it's been fine since then. |
