Dezod downpipe using stock bracing question, see if you guys can help??! Thanks!
Old Sep 4, 2009 | 01:29 PM
tofast4u's Avatar
Default Dezod downpipe using stock bracing question, see if you guys can help??! Thanks!
We are going to be using the stock manifold bracing to brace the downpipe and manifold a little better, seing how at 27 psi the motor is moving a whole lot. Just to make sure we dont have to much stress on the manifold and turbo assembly
So my question, how did you guys bolt the stock brace to the dezod downopipe bracket(the bracket near the bottom of the DP).
I cant get my stock brackets to work, I didnt know if there was a simple trick using both stock brackets together in a certain position or not.
thanks
Old Sep 4, 2009 | 01:53 PM
DezodDon's Avatar
longer bracket.
Old Sep 4, 2009 | 02:34 PM
ElevationTC's Avatar
27 psi! stock sleeves?!
Old Sep 4, 2009 | 03:58 PM
tofast4u's Avatar
LOL... stock sleeves yes indeed..
Actually, the stock sleeves arent THAT bad, Most ppl resleeve for a safe net. I think 500-550 whp is fine on stock sleeves.
Now as far as the tranny, I dont know how much longer it will hold, though it is fine right now
Old Sep 4, 2009 | 04:13 PM
SoFloTC's Avatar
stock bracket doesnt work.. i already tried.
Old Sep 4, 2009 | 09:43 PM
tofast4u's Avatar
Yes I see it doesnt work now. I even bolted the stock turbo back up in case it changed the position, but it didnt work.. way off
Old Sep 4, 2009 | 09:52 PM
so when you buy it, it doesnt fit? or it comes with brackets and you lost them.. just trying to clarify so people dont think the kit is missing peices when you buy it!
Old Sep 4, 2009 | 09:58 PM
SoFloTC's Avatar
the kit doesnt come with brackets for the DP
helloninja
Mar 19, 2018 04:50 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
TheTripleC
Jan 4, 2015 06:46 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
DjFrOsT
Dec 13, 2003 04:18 AM
