otbiker
09-08-2009, 08:16 PM
Trying to get to the fuse panel to wire my interior lighting, but can't remove the panel.
What holds this on???
2010 xB
2010 xB
View Full Version : Panel Below Steering Wheel otbiker 09-08-2009, 08:16 PM Trying to get to the fuse panel to wire my interior lighting, but can't remove the panel. What holds this on??? 2010 xB AndreyCo 09-08-2009, 10:33 PM Just clips. Grab the bottom of it and pull horizontally towards the seat. TrevorS 09-08-2009, 11:29 PM There are clips across the top too, so don't "hinge" it up from the bottom. The bottom starts it, but pay attention to the top as well. otbiker 09-09-2009, 02:09 AM I've really tugged on it, with no joy. This is a 2010 model. I wonder if there was a change from the previous year. Does the bolt need to be removed under the left kick panel? AndreyCo 09-09-2009, 02:23 AM I haven't seen a 2010 model so I couldn't tell you. I highly doubt they would change it though. TrevorS 09-10-2009, 11:23 PM I've really tugged on it, with no joy. This is a 2010 model. I wonder if there was a change from the previous year. Does the bolt need to be removed under the left kick panel? FWIW -- I found that starting at the bottom immediate right of the steering wheel gave the best results. That got it started and then working around the rest of the attachment points was easier. dlichterman 09-11-2009, 11:31 PM I believe I have a pic of the panel you are talking about in my Blu Logic install post, you need to start in the corner. Pics of the clips: http://www.scionlife.com/forums/showthread.php?t=171033 http://farm4.static.flickr.com/3528/3904582901_5bc3d5cc15.jpg |
