Need help! Car leans out!
Old Sep 13, 2009 | 07:18 PM
fullFXtc's Avatar
Default Need help! Car leans out!
Hey guys. Just trying to gt some input And see if anyone else has ever heard if this or seen it? So just got my car back from my tuner/mechanic and we were noticing the car lean out when you depress the brake pedal while sitting in park with car at idle! We checked the brake booster and the check valve, but somehow there is air getting back into the intake manifold? Has any one ever heard of this? Any info would help!
Old Sep 13, 2009 | 09:15 PM
weezyfbayba's Avatar
what kinda of bov do you have? and you have a vacuum leak somewere i had the same problem. and my pos hks bov was staying open at idle causeing my car to lean out at idle!
Old Sep 15, 2009 | 06:02 PM
fullFXtc's Avatar
Anybody else got any info??? Any help would be great!!!
Old Sep 15, 2009 | 06:04 PM
fullFXtc's Avatar
I doubt it's that bc the car would be lean allthe time and not just when u put ur foot on the brake.?
Old Sep 15, 2009 | 11:27 PM
lol no. my car ran ok when it was driveing when i come to a stop to idle it lean'd out. start ur car. let it run. unplug the vac line from the bov. if ur afr's go back to normal. there u go. other than that. check all vacuum line's you got a leak
Old Sep 15, 2009 | 11:31 PM
jjos1's Avatar
I would check all the vac lines first, what fuel managment are you using ?
Old Sep 15, 2009 | 11:37 PM
check the bov do what i said if you have the hks bov. i had the same exact issue ur haveing. the bov failed. if that doesint work. get some MAF cleaner and spray around all the vacuum line's and every coupler!
Old Sep 16, 2009 | 08:10 PM
fullFXtc's Avatar
im running the emanage set up right now. checked the bov... its not that! what we found was that theres a vacumm line coming from the brake booster and going to intake mainfold. we think were getting air fromo there??? but the brake booster and the check valve are checking out ok!
so were still kinda stumped??? dont know exactly how the air is getting into the manifold???
Old Sep 17, 2009 | 03:11 AM
jjos1's Avatar
What does your boost gauge read at idle ? you should see around -22 at idle
Old Sep 17, 2009 | 07:20 AM
Go4shoped's Avatar
My car does this too and im not boosted. I'm barely modded. lol.
I think its normal. I usually hit around 16.8 if i keep on hitting and releasing the brake.
Old Sep 17, 2009 | 10:22 AM
fullFXtc's Avatar
dont know what the boost gauge reads?? ill check it out and let you know.
thats what mine will read also!! right around 16.8 ???
Ramroids55
Jan 16, 2015 02:42 PM
PTUNING
Dec 11, 2014 08:09 PM
PTUNING
Dec 6, 2014 03:58 PM
tC_Normo
Oct 22, 2003 07:20 PM
2fixA
Oct 6, 2003 05:01 PM
