ARP Head Stud Install and hand tight..
Old Sep 14, 2009 | 03:24 AM
garynkim's Avatar
Default ARP Head Stud Install and hand tight..
Hey guys, need some help with tighten ARP Head studs, if you guys use any thread sealant or lock tight or Moly lube on the head studs,? (on the short block/bottom end)
I'm kind of iffy just hand tighten them. Right now i use a glazed coating of Moly lube on them and gorilla hand tight them with an Allen key.
Will I be OK?? Thanx..
__________________
Old Sep 14, 2009 | 03:26 AM
gingles's Avatar
the head studs should have came with lube...if not i hear oil is fine...like a 10w30....and you dont need to tighten em anymore with an allen key....once the heads on tighten the nuts to 35,60,80
Old Sep 14, 2009 | 03:38 AM
garynkim's Avatar
so moly lube is ok?? on the bottom end of the block. i was reading somewhere that if its in the water jacket area you gotta use thread sealant but i already used moly lube on it and hand tighten them... i guess it should be ok.. or should i check it out...
Old Sep 14, 2009 | 12:37 PM
yamaha16bw's Avatar
i used the moly lube on both ends on mine.
Old Sep 14, 2009 | 01:17 PM
ElevationTC's Avatar
moly lube and hand tight.. the stress of tighting down the bolt on the stud holds them in place!
Old Sep 14, 2009 | 04:00 PM
DezodDon's Avatar
As stated. Hand tight with an allen. Use moly lube on the threads, a light coating.
Old Sep 14, 2009 | 04:52 PM
garynkim's Avatar
cool thanx every1!! ill get some pics when i get a chance most likely from my cell.. but hey its better then nothing...
Dim
Oct 31, 2012 01:33 PM
sebbyxtc
10
Nov 23, 2011 06:58 PM
thendawg
Jun 16, 2009 04:43 PM
RSracer
Mar 21, 2009 03:39 PM
