Help!!! Cel p2102 with aem f/ic tuned with dezod pnp harness
Old Sep 15, 2009 | 12:58 AM
16G-Scion's Avatar
Default Help!!! Cel p2102 with aem f/ic tuned with dezod pnp harness
I bought a turbo kit with a pre-tuned AEM F/IC and PnP Dezod Harness and apparently the shop installing the kit has just finished connecting the AEM unit with the ECU and as soon as they fired up the car, it threw a CEL (P2102 THROTTLE ACTUATOR CONTROL MOTOR CIRCUIT LOW) and the gas pedal doesn't respond at all. Yet when the AEM unit is unplugged/removed, NO CEL and the gas pedal/throttle works great.
Any ideas or suggestions on this would be greatly appreciated guys!!!
Thanks!
Old Sep 15, 2009 | 01:07 AM
B_Real45's Avatar
Did you do the calibration before turning on the car? Make sure your TPS is calibrated on the FIC.
Old Sep 15, 2009 | 01:08 AM
ElevationTC's Avatar
im guessing short.. or ur not plugging the car side of the harness in correctly! or vise versa! check every pin and make sure its not bent!
Old Sep 15, 2009 | 01:14 AM
16G-Scion's Avatar
I'll have the shop try this out...I called AEM and he says most likely need to run the calibration tool...
Old Sep 15, 2009 | 01:52 AM
16G-Scion's Avatar
So this might cause the gas pedal not to respond...
Old Sep 15, 2009 | 01:54 AM
B_Real45's Avatar
Yes - it's like what you posted a couple of posts earlier - what the AEM guy had said..
You can calibrate your rpms and TPS.. definitely need to do the TPS first.
Old Sep 15, 2009 | 01:56 AM
16G-Scion's Avatar
the AEM guy wasn't 100% sure actually...just trying to confirm...thanks guys!!!
Old Sep 15, 2009 | 02:15 AM
crush02342002's Avatar
are you an auto by anychance?
Old Sep 15, 2009 | 02:23 AM
16G-Scion's Avatar
Nah 5-speed manual
Old Sep 15, 2009 | 04:59 AM
m6ar2cel6oTC's Avatar
i got that code everytime my TB messed up but it has to do with the tune! cause i highly doubt its your TB if you plug in your stock ecu and works fine.
Old Sep 15, 2009 | 05:53 PM
16G-Scion's Avatar
The shop installing the FIC says that something might be wrong with FIC harness and Dezod doesn't have any in stock to replace it
Old Sep 15, 2009 | 05:54 PM
B_Real45's Avatar
Well do they know or do they "think?"
They should check the wiring diagrams for the harness and against the ECU pinouts.. no guess-work here..
Old Sep 16, 2009 | 03:25 AM
16G-Scion's Avatar
The S.O.B who told me that the turbo kit and all the components were made for an 07+ sold me a turbo kit with a 06 PnP harness!!! That's why the car was shooting off the fault codes...
Old Sep 16, 2009 | 03:32 AM
weezyfbayba's Avatar
the only thing that wouldint fit from a 05-06 to a 07+ is the MAF sensor if the maf sensor hole fit's your intake pipe then the kit is right.
Old Sep 16, 2009 | 03:35 AM
16G-Scion's Avatar
Hmm your right...
but this turbo kit is a little different...I bought the remote STS turbo kit off the guy...the only one custom made for a TC actually
Old Sep 16, 2009 | 04:13 AM
lol that rear mount turbo shizz?
Old Sep 16, 2009 | 04:18 AM
16G-Scion's Avatar
Yeah dude...I must be crazy! hehe
I just wanted a turbo setup in my car regardless where the turbo was mounted LOL! But the original owner only had it set to a measly 4psi...
my06tc
Jun 25, 2015 12:18 AM
Zman
Apr 10, 2015 08:04 PM
mav261
Mar 24, 2015 01:19 AM
mav261
Feb 11, 2015 02:43 AM
