View Full Version : Weird Noises in front left tire
pocketbusXB
02-02-2005, 02:46 AM
Ok i just got some rims and installed some goldline springs and its been a couple of days already and all of sudden today my front left tire starts making noises everytime i hit a bump or little pot holes. sounds like something hittin it or seems like my in my tires loose. does anyone think they know what it is? maybe somethings missing
xB_Rida
02-02-2005, 03:46 AM
Tires rubbing on the wheel well or springs dont have enough "cushion" room when they compress and bottom out.
chadfo
02-02-2005, 04:08 AM
I have the same problem except I have Tein S-Tech springs. It doesn't seem to effect performance but it is annoying.
pocketbusXB
02-02-2005, 06:23 AM
yessss its really annoying seems like wheels about to break on me or fall off. is there any way to fix this ?
pocketbusXB
02-02-2005, 06:38 AM
djct_watt
02-02-2005, 06:50 AM
does it happen more when there are a lot of people in the car or?
hotbox05
02-02-2005, 08:09 AM
check every nut and bolt.
aireck
02-02-2005, 08:59 AM
it might be your bumpstops... check to see if they are still good,
i had the same problem and found out they were my bumpstops(they split in half down the side)
it wouldn't hurt to check'm
pocketbusXB
02-02-2005, 09:29 AM
no it happens anytime not just when theres hella people. hmm maybe ill check my bump stops i hardly doubt thats the problem. and i already checked all nuts and bolts.
aireck
02-02-2005, 09:33 AM
you know what else it can be ....
the bolt on the top of the strut under that lil rubber cap ...
tighten it a lil more ...real tight , that might fix it..
hotbox05
02-02-2005, 09:47 AM
yeah upper strut mount can do that
Spider13
02-02-2005, 12:02 PM
It's the big bolt on the top of the strut. Mine did it when it got loose. I think its from not using an impact wrench to tighten that nut., since the stud spins in the strut, it makes it hard to get it hand tight. (even though I'd have sworn my were tight, when I installed my springs, and checked them about 500 miles later). It may need some locktight.
pocketbusXB
02-02-2005, 09:01 PM
Yeah i was thinkin that was it too im probably going to go ahead and check that. THANKS guys
