What is your Turbo tC Drag wheel and tire setup??
Curious to see what others are running at the track as far as drag wheels and what size slick
Justin
Justin
Those are street tires, which i use.. but i spin 4th gear in them..
justin do not get the 8" wide slicks YOU will spin them.. i cant catch a decent 60 ft no matter how much we warm them!
Best ive had is 1.80 but if you take a look at my youtube.com/elevationtc videos you will notice in my 12.4 run i spin in 1st
you are most likely running too much psi if thats happening. lower the psi down to about 9 psi or when they start to wrinkle. i have the same size tires on weld 15x8 rims. you wouldnt want to really launch the car that hard though, because you most likely break an axle with that much traction.
I was running 9 psi in the tires.. exactly .. and 2steping at 10psi of boost at 5200 rpms..
im also going to be looking into that os giken unit very soon as well as one of my next mods.
