Difference 05-06 / 07/08 Head Studs
Old Sep 17, 2009 | 09:58 PM
johnhawkins's Avatar
Default Difference 05-06 / 07/08 Head Studs
Can I use the 05-06 headstud kit on a 08 block? If not I am selling them if any one is interested. Thanks.
Old Sep 17, 2009 | 10:01 PM
cburglb34's Avatar
no....the 07 and 08 ones are longer for a reason
Old Sep 17, 2009 | 10:34 PM
So its based on what year block you have correct? I have an 08 block but am using an 06 built head so I should use the 07-08 stud kit?
Old Sep 18, 2009 | 12:28 AM
and I believe the 07/08 ones are shorter-any one?????
Old Sep 18, 2009 | 01:39 AM
cburglb34's Avatar
idk but use the same as what your block is, so 7/08 tho u should have gotten 08 head too seeing the cams are more aggresive
Old Sep 18, 2009 | 01:53 AM
Ill most likely buy the BC cams to throw in anyways - If not Ill just use my stock cams that come with my 08 - The head I bought is from KarKing so its new pretty much - I just dont understand...if you look at the difference between the studs. the whole stud is longer not just the bottom threads which doesnt make sense to me because it seems as though the head would have to be different too. Such a pita
Old Sep 18, 2009 | 02:02 AM
cburglb34's Avatar
if u do decide to go with BC get the n/a cam it creates more power efficiently
bbsciontc
Scion tC 1G Wheel & Tire
Aug 19, 2019 01:46 AM
VitaminE
Mar 24, 2015 03:36 PM
bnutz313
Mar 3, 2015 06:06 PM
BManAmericae
Jan 18, 2015 12:17 PM
