TRD Supercharger Balancing
Old Sep 22, 2009 | 07:06 PM
tCZion's Avatar
Default TRD Supercharger Balancing
Im searching about the balance of the S/C and not find anything. I need to replace the seals and since I need to part out the S/C I want to know if need to be balanced, I notice that it has a mark in the bolt and shaft on turbine side. It is safe to only put it again in that mark? Thanks!
Old Sep 23, 2009 | 01:47 AM
SoccerBoy_AP's Avatar
Check out:
http://www.superchargedscions.com/Su...s/Welcome.html
or
http://www.tcsuperchargers.com/tC_Su...gers/Home.html
Old Sep 23, 2009 | 03:48 PM
SoulXquisite's Avatar
-PM gompka, he is a very good and reliable source that knows about trd tc SC.
Old Sep 24, 2009 | 04:52 AM
gompka's Avatar
balancing the shaft is better for the longevity of your bearings. But to do it you would need to take off your bearings and take it to a place to get balanced to 12,000 rpm then put the bearings back. The stock bearings are garbage, and personally i won't mess with getting the stock shaft balanced. If you do decide you want to though, atleast get the better bearings. I can supply just the bearings for you if you want pm me.
Old Sep 24, 2009 | 05:22 PM
tCZion's Avatar
When you rebuild the S/C, do you balance??? So it is safe to just put the marks in same place??
I see your rebuilds kits and are the best that we have it accessible.
Thanks!
Old Sep 24, 2009 | 11:50 PM
gompka's Avatar
Thanks!
You don't need to mark anything when taking it apart and putting it back together. The shaft isn't balanced oem. I stress again to change the pulley bearings if you have the shaft out already. It won't cost very much and will be a lot easier to do since you'll have the charger apart.
Btp907
Sep 15, 2015 02:54 AM
vintage42
Sep 12, 2015 12:59 AM
mxwes
Aug 30, 2015 09:11 PM
