Back to stock but running rich
Old Sep 23, 2009 | 02:53 AM
dave2610's Avatar
Default Back to stock but running rich
i got the kit off and im back to stock but now the car appears to be running rich. The exhaust has a heavy smell of fuel. Any ideas why that is and how i could fix it?
Old Sep 23, 2009 | 03:06 AM
Tc4Eva's Avatar
Team ScionTific
Did you reset the ecu by disconnecting the Neg terminal on the batt?
Old Sep 23, 2009 | 05:55 AM
crush02342002's Avatar
running stock injectors?...its going to take a couple of days for it to return to normal...you can speed things up by driving around roughly 40 miles...it helps
Old Sep 23, 2009 | 02:02 PM
THansenite's Avatar
Disconnecting the battery will be the quickest way. You need to reset your fuel trims.
Old Sep 23, 2009 | 02:19 PM
davedavetC's Avatar
wouldnt everything reset once he pulls the piggyback off and the kit off, puts back stock injectors and all other stock parts? the monitors would reset back to normal after a certain about on driving
Old Sep 23, 2009 | 02:23 PM
Ace83's Avatar
Ronin Scion
oh stock plugs too! but yeah reset the ecu and its should clear the fuel trims it made with your tune
Old Sep 23, 2009 | 02:52 PM
yes both ways work...resetting the ecu or just driving around for a bit will do the trick.
Old Sep 24, 2009 | 12:40 AM
B_Real45's Avatar
Did you ever upgrade your fuel pump?
Old Sep 24, 2009 | 02:44 AM
dave2610's Avatar
na still have the stock pump. ive reset the ecu and its still rich. im also getting a cell im going to find out what code its throwing tomorrow. I guess that could be causing it to run rich we shall see
Old Sep 24, 2009 | 02:52 AM
cburglb34's Avatar
yes check that out asap, plus better to run rich than lean =P
Old Sep 24, 2009 | 11:51 AM
ElevationTC's Avatar
mafffffffffff
Old Sep 24, 2009 | 01:28 PM
Ace83's Avatar
Ronin Scion
yeah check the code, it could be your maf or your O2 sensor went bad.. But try driving the car for a bit and it should adjust the your fuel trims to where the ecu wants it
Old Sep 25, 2009 | 08:28 PM
dave2610's Avatar
So the code it's throwing is p0171 system to lean. Any ideas
Old Sep 25, 2009 | 08:31 PM
DezodDon's Avatar
Resetting the fuel trims is not done by simply disconnecting the battery. You must discharge all the capacitors in the ECU first. Disconnect both battery terminals and touch them together for 2 or 3 seconds. Done. Reconnect and the car will be set to relearn fuel trims. Also check all the work you did and make sure that there are no loose vac lines.
Old Sep 25, 2009 | 09:28 PM
dave2610's Avatar
Checked vac lines. no leaks. Gonna Clean maf and reset ecu like don said
Old Oct 5, 2009 | 03:27 AM
dave2610's Avatar
Update: No vac leaks and i cleaned the MAF sensor but it was still throwing the code. So i replaced the primary O2 sensor and that seems to have fixed it. Ive driven for like 30 miles and the code hasn't returned. It would come on almost instantly before.
Old Oct 5, 2009 | 12:58 PM
maybe that was ur problem all along with the turbo kit
Old Oct 5, 2009 | 01:09 PM
Ace83's Avatar
Ronin Scion
yes.. or maybe your tune made your O2 sensor to fail prematurely
Old Oct 5, 2009 | 06:11 PM
o2 sensors and be fouled too
Old Oct 5, 2009 | 08:31 PM
dave2610's Avatar
na turbo seals are bad. the old o2 sensor wasnt mine and it had been sitting for quite a while
fur_pig
Scion tC 1G Wheel & Tire
Jan 14, 2019 12:03 AM
ft86chick
Scion FR-S ICE & Interior
Jan 8, 2015 05:59 PM
cid_mcdp
Jan 5, 2015 02:45 PM
TheTripleC
Jan 4, 2015 06:46 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
