Turbo help plz!!!
Old Sep 24, 2009 | 06:42 AM
vk5112's Avatar
Default Turbo help plz!!!
I just finished installing a custom stage 0 kit on my car. My wastegate has a 5.9 spring. But at full throttle it boosts up to 7 psi. Can somebody help me fix this.
Old Sep 24, 2009 | 07:25 AM
draxcaliber's Avatar
you could swap to a lower psi spring, or install a boost controller. also, i hope you are running some sort of engine management with it.
Old Sep 24, 2009 | 07:46 AM
athletefeet66's Avatar
take a pic of your vac lines.
you have the 4lb wastegate spring if you want to put that in
Old Sep 24, 2009 | 11:55 AM
chicotunner07's Avatar
if its a true ZPI stage 0 then it should run "ok" without management, its not recommended, but not absolutely necessary when only running 4-6 pounds of boost, but be careful with those spikes, they are definitely dangerous!
Old Sep 24, 2009 | 01:46 PM
ElevationTC's Avatar
how can installing a boost controller help him...?
Old Sep 24, 2009 | 02:31 PM
rangerryda's Avatar
It controls boost gosh! lolz
Old Sep 24, 2009 | 02:33 PM
Yea.. upwards not downwards!
he's trying to run less boost! not more!
Ive never seen a boost controller make its own pressure!
Old Sep 24, 2009 | 02:43 PM
Ace83's Avatar
Ronin Scion
I think what he meant using boost controller is that so he could up the boost when needed since he is gonna be using a smaller spring
Old Sep 24, 2009 | 03:07 PM
skinnayyy's Avatar
Team Scionara
yeah you most definately want to quadruple check all your lines. Because having spikes like that with no management or anything will bad news bears for your engine.
Old Sep 24, 2009 | 05:38 PM
rangerryda's Avatar
Good god Mike, I hope you didn't think I was serious! lol
Old Sep 24, 2009 | 05:40 PM
you had me realllllly scarred bud
Old Sep 24, 2009 | 05:51 PM
crush02342002's Avatar
lots and lots of things can make you boost higher than what the spring is rated for..
1. vac leak to wastegate
2. fittings on wastegate not sealing
3. pinched hose to wastegate
4. using crappy vac hose to wastegate that when it heats up it collapses or pinches
5. cheap wastegate
6. cold weather can make you boost 1-2psi over wastegate spring at times
just to name a few.
Old Sep 24, 2009 | 11:08 PM
Rob_DESCENDANT's Avatar
Boost controllers only work for increase boost over the wastegate spring, not lower it.
SloTC1
Aug 16, 2018 02:45 PM
greytc
Oct 26, 2015 07:53 PM
CrowJenkins
Oct 9, 2015 10:47 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
JonathonK
Sep 22, 2015 07:27 PM
