View Full Version : Removing XB Rear Seat.
tbone587
02-02-2005, 11:23 PM
Does anyone know how to remove the rear seat in the xb? I cant seem to figure out how to remove it and I dont want to brake it. I need to take it out to finish running wires to my amp in back
chadfo
02-02-2005, 11:28 PM
You can run the wires without taking it out. Just lift up on the front and you can run under it. To get it completely out there is a loop in the middle at the rear of the seat. It is a pain to get off the hook but that's all that holds it in.
tbone587
02-03-2005, 01:34 AM
interesting... a loop in the middle of the seat is it on the front closer to the drivers side, or is it in the back where the backrests of the rear seats are/
Cockpit_XB
02-03-2005, 03:32 PM
if you fold down the top of the rear seat you can see where that hook is for the bottom of the seat. You can take out the bottom of the rear seat out youself but its better if you have someon help you because it is a _____ to do it. But if you want to run wires under the seat just lift up the front part of the seat & slide the wires through, you might be able to lift it really high only due to the fact that the seat belt buckles get stuck in the pocket that they sit in. Hopes this info helps you.
