Wat is this?
Old Sep 25, 2009 | 07:01 PM
scion_andrew's Avatar
Default Wat is this?
Wat is this inbetween those two gold bolts?
when u move it it moves something inside the turbo housing.. is it sometype of internal wastegate?
thanks
its a garret 50trim with .58 ar
Old Sep 25, 2009 | 07:17 PM
kirk212's Avatar
Its the lever that the wastegate actuator pushes on that opens up the flap within the turbo to control boost pressure
Old Sep 25, 2009 | 07:30 PM
So do i remove this? im gonna use a extrnal wastegate,
or wat do i do?
Old Sep 25, 2009 | 08:00 PM
rhythmnsmoke's Avatar
Music City Scions
Yeah you need to remove it and have the flap welded shut.
Old Sep 25, 2009 | 08:13 PM
paul_dezod's Avatar
Scionetics
KAD
If that is a .58 AR than it is probably a t4 flanged turbo in which case you probably got that of of a diesel. Usually wastegate flappers are on the other side of the housing but on garrets they are not usually part of the housing at all.
If you took this from a diesel (which I am making an educated guess) then this turbo is a VATN turbo. Which means it has a variable actuated turbine nozzle. There are a second set of turbine blades inside the housing which change pitch to make best use of the available exhaust energy. Very common on diesels where load is kind of a problem with no throttle blade and what not.
Did you take this from a ford power stroke?
~don
Old Sep 25, 2009 | 08:45 PM
~don
I really dont know where it came from i got it off craigslist for 60 bux,
I mean if i remove it an have it welded shut will i be able to use it on my car?
Old Sep 25, 2009 | 08:58 PM
DezodDon's Avatar
Do not remove it.
That is your wastegate, technically.
You can't use it without the diaphragm actuator or the VATN solenoid. It's pretty much useless.
I will take it off your hands though for $60.
Old Sep 25, 2009 | 09:32 PM
crush02342002's Avatar
iv worked on three ford diesels...one i remember had a 1.(something) housing (think it was a 94-95 power stroke)...all three had very large housings with one that i can remember having v-band connections. idk if that helps or not...im sure ford had many different turbo styles that they used but all were garrett.
Old Sep 26, 2009 | 05:43 AM
So wat should i do sell it or use it?
Old Sep 26, 2009 | 12:48 PM
Music City Scions
Originally Posted by DezodDon
Do not remove it.
He said he was converting to an external WG.
Old Sep 27, 2009 | 05:38 PM
dave2610's Avatar
rhythm if thats a vatn turbo it has to be there
Old Sep 27, 2009 | 06:09 PM
Well i put it up for sale in the ppc if anyone wants its, i just orderd a 57 trim , i didnt wanna mess with it.
i cant wait 2 boost!
Old Sep 27, 2009 | 08:24 PM
Music City Scions
I was just assuming, going by what's on the 16G, 20G. As those are internally gated, and just welded shut to run external.
beezyyy
Jan 26, 2006 07:46 PM
ballnxb08
Scion tC 1G Aero & Exterior
15
Jan 25, 2006 07:03 AM
SpUnKyTC
Sep 18, 2005 09:45 AM
mikek6789
27
Jul 6, 2005 02:16 PM
S-Tekk
Jun 17, 2005 01:45 AM
