Turbonetics kit help
Old Sep 26, 2009 | 11:35 PM
turbonetics_tc's Avatar
Default Turbonetics kit help
Today I put on my turbo kit, and when I was done I started the car up. It started up fine; it was running between 19 and 20 on the vac. So I checked around to see if there were any leaks, but everything was good so I gave it some gas and took it up 4000 rmp. It started to build boost but then it went to go negative vac, and then started to run bad and blowing out white. Every time you gave it some gas it went negative on the vac, then idle real bad and vac would be around 10. So does anybody have any idea would could be wrong.
Old Sep 26, 2009 | 11:43 PM
GookStar's Avatar
Bov waste gate?
Old Sep 26, 2009 | 11:52 PM
Ok I found one of the intercooler pipe came off, so when I get that put back place and start it up again it should be fine. But if it were to continues to do the same thing when I do fix the pipe, what could be the problem.
Old Sep 27, 2009 | 12:09 AM
crush02342002's Avatar
you have more leaks than you know...lol
Old Sep 27, 2009 | 12:23 AM
rangerryda's Avatar
There has to be a major vac leak if you only get 10 vac at idle. Check everything, ten times over.
Dbonehead6
May 28, 2015 12:15 AM
B_Real45
Feb 23, 2015 07:33 PM
oxxomxxo
Jan 26, 2015 08:23 PM
Ramroids55
Jan 16, 2015 02:42 PM
