Dash Light for Parking Brake comes on when Accelerating
Has anyone had this issue? On my 2007 tC the "Brake" light on the dash is coming on when I am accelerating. The parking brake is completely in the down (disengaged) position. Wondering what would be causing this light to come on? The light does not stay on just lights up in the higher rpm range and then goes out again.
Almost...
If the fluid is low, it is because your front pads are likely low - which causes there to be more fluid in the lines, which means less fluid in the reservoir.
Check pads first. If they're OK, check the fluid in the reservoir. If those are both OK, take it to the dealer.
Regardless, a quick search and you would have found this thread no problem:
https://www.scionlife.com/forums/viewtopic.php?t=185625
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
randode
44
Jun 29, 2004 04:19 PM
accelerate, accelerating, accelrating, acellerating, brake, break, dash, emergency, issue, light, pacifica, parking, scion, tc, turns, xa
