Help with my driver seat and clazzio cover
Old Oct 3, 2009 | 02:29 AM
celestialeve2k1's Avatar
Default Help with my driver seat and clazzio cover
Hi,
I installed both the passenger and the driver clazzio seat cover today and I have a problem with my driver side. I tried to push it down, so that you can lay down on your back. Well if I use the side lever or whatever you call that thing to make it go down it wouldn't do it. It would move a bit, but then it's stuck. When I use the one on the bottom chair to move it then it works perfectly. Then when I tested the top again it work, but now it woudn't click anymore to stop. Now, even the lower one doesn't work. So my chair is basically loose! Please help!
My Dad said he'll look at it tomorrow, but do you guys know what we did wrong? We we're both working on it. Sorry, if my explanation confuses you, but I tried to explain it as best as I can.
Thank you
Old Oct 4, 2009 | 04:41 PM
Kanchi's Avatar
I would try to take it to both extremes of how it is supposed to go...other than that alsmost sounds like you broke the internal latch? You try to force it?
Old Oct 4, 2009 | 10:28 PM
Scionriderz's Avatar
okay calm down it is possible that you just disconnected the wire in the chair. its very simple to fix just remove the chair from the car and have a set of pliers available. there will be a series of wire loops on the bottom of the chair *remove them not cut them* because you can reuse them. now with all of them removed just take the fabric off and you will see the mechanism that controls the chair. hope this helps cause my passenger chair top lever stop working till i checked it out and it was just the wire. hope this helps
lvlisslvlelissa
Scion xD ICE & Interior
Oct 13, 2023 03:40 PM
MandoRob
Jul 11, 2015 11:11 PM
stillcole
Scion tC 2G ICE & Interior
Apr 6, 2015 03:42 PM
10ecman
Scion tC 1G ICE & Interior
Mar 28, 2015 12:39 AM
subcode
Dec 6, 2003 11:28 PM
