silver
02-03-2005, 11:58 PM
hay how hard is it to remove both the honeycomb grills i want to put the t-rex grills in?
thanks do you have to take the bumper off?
View Full Version : how hard to remove the honeycomb grill ????? silver 02-03-2005, 11:58 PM hay how hard is it to remove both the honeycomb grills i want to put the t-rex grills in? thanks do you have to take the bumper off? chadfo 02-04-2005, 12:21 AM It's not hard but it can be a pain. You can either reach under the front and push down on the tips of the tabs that hold it on or you can put something dull and flat between the grill and the body at the tabs and pry up. I've done it both ways. The first way is most difficult and time consuming. The second way is very quick but you rish damaging the paint dgHotLava 02-04-2005, 12:30 AM moved.... unlmtdndeavor 02-04-2005, 02:22 AM if u want to make sure u dont screw up your bumper, take it off. then u can clearly see how the grill is mounted and just pop them off. it doesnt take much to remove the bumper. just make sure to get all the bolts off before u try to pull the bumper off. flowmini98 02-04-2005, 02:39 AM yeah i would remove the bumper just to be sure it dosent get messed up. |
