replace synchros
Old Oct 8, 2009 | 04:31 PM
chintastictc's Avatar
Default replace synchros
anyone know where i can buy a synchro kit?
Old Oct 8, 2009 | 05:00 PM
ack154's Avatar
I don't know about a "kit" but I'd start checking junk yards.
Old Oct 8, 2009 | 06:18 PM
my06tc's Avatar
did yours go out or something
Old Oct 8, 2009 | 07:52 PM
no it just wont go in gear or come out sometimes and it ALWAYS grinds third
Old Oct 8, 2009 | 08:22 PM
my06tc's Avatar
what gear oil are u using....reason i ask that can affect the problems your having...
Old Oct 10, 2009 | 02:02 AM
Supra12big's Avatar
pennzoil snycromesh is your friend. 6 bucks a quart and u only need 3. Try it and readjust ur clutch pedal, u will love it.
Old Oct 10, 2009 | 02:04 AM
i hear so many different oils to use
Old Oct 10, 2009 | 03:33 AM
jctc06's Avatar
hey man im having the same problem RIGHT NOW ok when my car is on it wont go into gear but when i turn it off it goes in so ill leave it in gear then i start it up and it already starts moving without me even letting go of the clutch. Could it be the synchros for sure or could it be the clutch not disengaging this really sucks let me kno if u have any luck man.
Old Oct 10, 2009 | 03:51 AM
engifineer's Avatar
^^ that is not synchros, that is your clutch not disengaging fully.
Old Oct 10, 2009 | 05:24 AM
Coolwaterz's Avatar
sounds like our clutch is F-ed up.
also when u get that clutch fixed go all out on redline or amsoil transmission oil. dont get that mobil one ****
Old Oct 10, 2009 | 12:09 PM
ElevationTC's Avatar
Your syncros are not bad..
What is bad are your shift sleeves!
2nd to 3rd sleeve
And probably ur 5th is worn.. They go bad as well!
Its about 150.00 in parts 75 per sleeve and the job isint to bad! But you need a tranny expert!
K Thnx
Old Oct 10, 2009 | 11:06 PM
jctc06's Avatar
I just needed some different opinions on wat it could be. Just so i know it wasnt the transmission cause that wouldve been worse for my situation right now.
Old Oct 11, 2009 | 06:59 PM
my06tc's Avatar
i dont recommed redline gear oil i personally had problems with it..i use eneos to thid say no problems.....trying changing your gear oil to any of the above oil that in mentioned most likely that will solve your issues if not then you may have some tranny issues
DaBlackBox
134
Apr 10, 2022 02:04 PM
tato63
Scion tC 2G Wheel & Tire
9
Sep 30, 2015 09:55 PM
blh72
Scion xD Wheel & Tire
Feb 2, 2015 12:36 AM
torranosaurus
Jan 28, 2015 04:53 AM
TheTripleC
Jan 4, 2015 06:46 PM
