stripped header bolt...
Old Oct 9, 2009 | 02:30 AM
flying_toaster's Avatar
Default stripped header bolt...
hey guys so today i was going to install a header in my 06 and one of the bolts is now stripped pretty bad from me trying to take it off. before you guys say search how to take out a stripped bolt, i already did and there is no way the techniques i found would work in this case due to the lack of room where the bolt is. its the top middle one connecting it to the block... so my question is HOW DO I GET THIS BOLT OUT
Old Oct 9, 2009 | 02:42 AM
jct's Avatar
jct
quick search on yahoo...
http://www.ehow.com/how_5454398_remo...paign=yssp_art
http://www.ehow.com/way_5384802_tool...ped-bolts.html
http://answers.yahoo.com/question/in...AAtUvgl&show=7
Old Oct 9, 2009 | 02:52 AM
again, i researched all the option but if you realize how much room there is back there, none of those techniques would work.
Old Oct 9, 2009 | 03:49 AM
RedneckwithanxB's Avatar
Its been a while since Ive been working on my header, so forgive my retardedness...
how about some vice grips, can you get them on it?
Dremel to cut into the bolt and then a screwdriver to get it off?
Old Oct 9, 2009 | 03:55 AM
jct's Avatar
jct
vice grips won't fit in there its plenty tight space (insert lewd comment here)
Old Oct 9, 2009 | 04:37 AM
gahhhhhhhhhhhh fml
Old Oct 9, 2009 | 04:56 AM
Needle nose vice grips maybe?
Old Oct 9, 2009 | 05:04 AM
tried that already...:?
Old Oct 9, 2009 | 05:11 AM
Um...
From a focus forum...
go to sears, and they sell a stripped bolt removal kit with like a reverse threaded type thing in a socket. from what i hear they work very well, but i dont know cause i have never used them before.
Old Oct 9, 2009 | 06:26 AM
daneisthegreatest's Avatar
Um...
^^thats exactly what i was thinking when reading the first post, you can actually get these from walmart too, but i would check out sears and get the craftsman version it might be better quality than stanley...
ive used these before and they do work, to give you more room you might want to take off the plastic piece under the wipers, that should give you about 3+ more inches to work with.
Old Oct 9, 2009 | 06:49 AM
Steventc07's Avatar
edit: lol not a tC, but that should work.
Old Oct 9, 2009 | 11:56 AM
my06tc's Avatar
if you have pics..we cold help you better
Old Oct 9, 2009 | 06:05 PM
MadMike550's Avatar
get a die grinder...and grind the head of the bolt off
use a vice grips on what is left after you get the exhaust manifold off
a dremel will work too..but it's going to take you some time
Old Oct 9, 2009 | 06:28 PM
MadMike, I wouldnt suggest going that far just yet. Only if the head of the bolt breaks off would I suggest that, because then ya gotta drill the bolt out!
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
CrowJenkins
Oct 9, 2015 10:47 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
Bimfi
Sep 4, 2015 08:15 PM
