*LEDmod.com xB2: Custom High Power 42 LED Domelight and Maplight
Scion xB2 : Custom High Power 54 LED Domelight and Maplight
Using high power 3-chip SMD LED technology
To order please click here for the link
Remove the lens using flat head screw driver (there is small notch)
Connect the socket, check to make sure it lights up(if it does not light up, flip the connection)
Peel off the adhesive film
Tuck the wires and stick it on, double check the light and put the lens back on
Connect the socket, check the light (if it doesn't light up, flip the connection)
Apply two layer of foam tape to secure the LED module and tuck the wires
Put the lens back on, check the light and align the module as needed
- Rear Domelight 54 LED(14 x 3-chip) : 5.0" x 1.5"
- Front Maplight 30 LED(10 x 3-Chip) : 1.5" x 1.5" [Comes as pair, two module for the maplight]
- Flexible super thin SMD design, 1/16" thick
- One of the brightest in the market
- Harness is design to fit the stock socket
- Plug and Play style installation
- Double sided tape for easy installation
- 1-year warranty
Installation Guide
Connect the socket, check the light (if it doesn't light up, flip the connection)Apply two layer of foam tape to secure the LED module and tuck the wires
Rear is the dome light (turns on when you open the door)
It's way way brighter then stock..
Just the dome light will light up the whole interior bright...
yes, it's a 2 piece set for the front maplights and 1 domelight.. they are leds.. and they are good quality.. they'll be a LOT brighter than stock.. white will light up your whole interior very well
Map light isn't needed, unless you want to see things really bright as needed base..
So basically "all in one set" includes
- Dome light
- Map light x 2
- Trunk light
Originally Posted by Tyrannosaurus RexB
is there a Form for ordering just the Map lights?
because I want them all. I just dont want to pay all 80 up front!
I can process it manually for you.
What color are you looking for??
