Turbonetics check engine light need your help.
Old Oct 9, 2009 | 09:15 PM
turbonetics_tc's Avatar
Default Turbonetics check engine light need your help.
Ok I got my car back from S&R Performance couple of day ago; they had gotten my car running again check engine lights gone and were able to tune it. The only problem I had was the car would hesitate if you were in 3 gear and you punched the gas, and same thing with 4 gear but it was worse than if you were in 3 gear. So I was driving today and noticed my check engine light came on, the car was driving fine no problems. I took it to auto zone to see what the check engine light was on for; here is the list for what came on. I don’t know what to do; this kit has been giving me nothing but problems. I don’t know if I should keep it on and work through it, or just take it off and try to get money back, and if I can’t just sell it.
here are the codes its putting out.
P0102 Mass or Volume Air Flow Circuit Low Input
P0121 Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance Problem
P0138 O2Sensor Circuit High Voltage (Bank #1 Sensor #2)
P0335 Crankshaft Position Sensor "A" Circuit Malfunction
P2112 Throttle Actuator Control System – Stuck Closed
P2135 Throttle / Pedal Position Sensor
Old Oct 9, 2009 | 09:48 PM
MIAPLAYA's Avatar
That's a lot of odd codes. Maybe the Unichip is bad? Have you tried replacing it?
Old Oct 9, 2009 | 09:56 PM
B_Real45's Avatar
I believe he's using FIC.
Old Oct 9, 2009 | 10:08 PM
crush02342002's Avatar
I could put money on that he is useing the fic....lol
1st i would start with calibrating the fic (throttle and rpm)
next i would double check the slave version
then look into doing the resistor mod
after all that id look at your maf and make sure it is seated properly with no leaks around it or around the charge pipes.
also if your still having that throttle code the tps may be unpluged or damaged. Check the fic harness and make sure its pluged all the way in, look for damaged wires.
if all that is done and your still having issues i would get another tuner...kinda sounds like the maf map may be fubar.
what year tc and auto or 5 speed?
(I know im missing something....)
oh yeah...try unplugging the fic and clearing the codes...leave the fic unplugged and run the car. dont go into boost but just run around and see if any of those codes come back.
Old Oct 9, 2009 | 10:30 PM
rangerryda's Avatar
The resistor mod should clear up the crankshaft code.
The O2 Sensor High Voltage is because your secondary is finding out the hard way that your car no longer has a catalytic coverter. Is the O2 boss installed on the secondary?
The MAF code is because of an improper tune. It's not clamped or tuned well enough for the cars ECU to not pick up on the changes being inputted.
The rest sounds like you need to calibrate the FIC and renew all the software. There is a sticky on that on the FIC setup thread.
I run the same kit but after much experience and learning (as well as tuning with Mike aka ElevationTC) I have no codes at all.
Just look at crush's sig.... lol that's for doing the oil feed line tapping during kit install! lolz
Old Oct 9, 2009 | 10:48 PM
Im using an fic with a plug n play harness, my car is 2008 5 speed with 12500 miles on it. Is there a way that it could be fic is going bad, or the plug n play is wired wrong. I was driving for a couple of day with out any check engine light coming on, and now they popped up.
Old Oct 9, 2009 | 11:13 PM
ElevationTC's Avatar
ur in tampa maybe someone local you can meet up with and swap harness's or come to me and get tuned! :0 And well check it out
Old Oct 9, 2009 | 11:17 PM
I dont know anybody local, were are you located at.
Old Oct 10, 2009 | 12:10 AM
How bad would it be to drive my car, with does check engine lights codes going off.
Old Oct 10, 2009 | 12:29 AM
lol
Old Oct 10, 2009 | 12:51 AM
Hix's Avatar
Hix
Mine are on and I drive it like I stole it. Maintenance Req'd light just came on though
Hell my tps light has been on since I got the car
Old Oct 10, 2009 | 12:57 AM
weezyfbayba's Avatar
go to elevation's place he will get it up and running on a nice fresh tune!
Old Oct 10, 2009 | 01:16 AM
Ya I need to look in doing that.
Old Oct 10, 2009 | 01:36 AM
we are meeting up wensday at his place. i can do the resistor mod for seriously dirt cheap and his tuneing is the best price around and tune is perfect
Old Oct 10, 2009 | 01:37 AM
the resistor mod and a good tune ur car will be running very nice. M tuned ftw!
Old Oct 10, 2009 | 02:01 AM
I wish I could I work Mon-Fri.
Old Oct 10, 2009 | 02:19 AM
tale off wensday! i drive all the way up from fort myer's her lives near orlando
Old Oct 10, 2009 | 02:27 AM
I wish I could but the military wont let me do that.
Old Oct 10, 2009 | 03:06 AM
rangerryda's Avatar
How much leave you got saved up? Wednesday huh? I'll be there but not till after 7 or so. You at MacDill? AFSC?
Old Oct 10, 2009 | 03:59 AM
I go back to work this monday, I been leave for about 3 weeks now. they wont let me take off any more time, ya I at macdill I am a kc 135 crew chief.
