For those with systems
Old Feb 5, 2005 | 02:21 AM
ih8civx's Avatar
Default For those with systems
where did you run your powerwires? i cant find any available gromets anywhere. also trying to find a doubledin dash harness is a pain. can anyone help with either problem?
Old Feb 5, 2005 | 03:43 AM
smurf3642's Avatar
If you're looking into the engine bay...Look in the top (very top) middle...or in the lower right...
Old Feb 6, 2005 | 12:03 PM
Mudd's Avatar
I drilled a hole through the firewall and used a plastic grommet. I have an a/t so it was easy - right through where the clutch master would be on a 5spd.
You can also go through the rubber grommet on the pass side where all the factory wires run through. Just make sure to silicone the hole so you don't get any water or noise.
Old Feb 7, 2005 | 03:54 PM
Wide_tC's Avatar
There is a rubber OE grommet on the driver side just behind the throttle body. It is in a recess on the firewall.
Old Feb 7, 2005 | 10:40 PM
ih8civx's Avatar
ill go hunting for it tomorrow, thanks!
Old Feb 11, 2005 | 05:27 PM
jwaggz82's Avatar
just so you know, i drilled a hole through the firewall and used the grommet. The grommet wore away after a while and caused the power cable to start to tear. This tear started to spark and my fuses were blowing all the time. I didnt realise this was the problem untill I narrowed it down. When i would hit a big bump, it would blow (sometimes). ANyway..just saying...watch out doing something like that.
yhwhdesign
Jun 11, 2021 03:34 PM
carid
Feb 10, 2019 10:46 PM
Hydryman
Feb 23, 2016 03:35 PM
brett561tc
Sep 15, 2015 06:33 AM
Subaru86
Jul 31, 2015 04:33 AM
