Broken LCD HVAC Screen Question?!?!? PLEASE HELP
Old Oct 16, 2009 | 12:20 AM
Malvagio1987's Avatar
Question Broken LCD HVAC Screen Question?!?!? PLEASE HELP
Okay so somehow my LCD broke on my HVAC ... i attached some pictures below. It doesn't display anything correctly to the left of the second hour digit. is there a way i can buy another LCD Screen for it and if so where? If anyone has any other ideas about it let me know.
Thanks in advance!
I have an 06 Scion tC btw if that makes a difference
Old Oct 16, 2009 | 12:48 AM
SquallLHeart's Avatar
sucks for you dude..
check junkyards.
Old Oct 16, 2009 | 01:16 AM
kmx22's Avatar
dang...you'd probably have to get a whole new HVAC
Old Oct 16, 2009 | 01:58 AM
Joyride's Avatar
check junkyards.
+2
/thread
Old Oct 18, 2009 | 02:41 AM
LEDmod's Avatar
You didn't mess with your LCD screen or take the unit apart??
Old Oct 18, 2009 | 05:21 AM
yellowxhoodie's Avatar
ebay.
Old Oct 19, 2009 | 04:12 AM
Aphex13's Avatar
The glass isn't broken... Just take the board out and reheat the solder. It's super easy. If you look at the opposite side of the board, you'll be able to see the legs from the lcd sticking out...
Old Oct 20, 2009 | 08:49 AM
No i never took it apart. It looks like a small crack happened in the LCD.
i dont think thats the issue ... i think i need a new lcd
Old Oct 20, 2009 | 05:05 PM
if you never took it apart.. go to the dealership and get them to replace it.
Old Oct 27, 2009 | 11:00 AM
grumpy6489's Avatar
i'd find a junkyard, or dealership. i got lucky and found one at a junkyard and did the swap myself.
Old Oct 27, 2009 | 12:40 PM
StatuSCheckA's Avatar
Be sure and double check your warranty status at a nearby dealership.
I broke mine by looking to see what LED's I needed, and I took it to the dealer and blamed it on the Texas heat....got a free installed replacement same day.
Old Oct 31, 2009 | 06:41 PM
Garage1217's Avatar
I can source an hvac for you & also perform a swap if you like. That is, if the dealer does not take care of you. Cracking the screen is VERY difficult to do when it is inside the waterfall, so would have to be a defect. Hit me up if you need any help or have any questions on the matter. Happy to help.
Old Oct 31, 2009 | 06:55 PM
engifineer's Avatar
That does not look like a crack to me... and trust me, I have worked on a LOT of the HVACs as have Jeremy and Trung (garage and squall).
A crack would end up bleeding through.. a black line would first appear and it would then start to form a black spot. I am not seeing that in the pics.
Reheating the solder on the backs of the pins is the first thing to try. Takes about 10 minutes.. including removing the HVAC from the car, if you have a soldering iron and know how to do it. After reheating them (without overheating them) I would check for shorts between the pins. This can happen on the other side of the board if too much solder was originally used.
If none of that works, then it could actually be a bad LCD or an issue on the board itself. If you are going to leave the color stock, then I would just look on car-part.com for a replacement (give them the right year model. For an 06 you can use either the 05 or 06 unit, but not the 07+). You can usually get one for well under $100.. and most include the waterfall which you could resell.
This is, of course assuming you have no bumper to bumper warranty left. You dont want to pay the $500 or so for a new one.
Old Oct 31, 2009 | 09:43 PM
o8tC's Avatar
this happened to me while doing the led swap on my hvac. mine had a huge black dot right in the middle. had to get a whole new one from someone here on the forum. paid like $25 shipped.
Old Nov 1, 2009 | 06:27 AM
i've actually seen cracks in a LCD where over time or even when it happens.. where the "ink" doesn't bleed through at all.
there is a possibility that there is a crack still that we can't see in the pictures.. however i would have the dealership replace it for free..
and if they refuse to do so.. bring it up higher and figure stuff out from there.
Old Nov 1, 2009 | 02:23 PM
engifineer's Avatar
Yep, I have seen those as well.
I have also fixed a few for people where it was a solder bridge or bad joint on the pins causing it too. Normally that is after they did an led swap, but it is possible to have a bad joint from the factory as well.
Old Jul 31, 2010 | 06:58 AM
SHELZOtC's Avatar
o8tC, PLEASE tell me where you got that hvac lcd screen PLEASE! same thing just happened to me. if you really got that screen without purchasing the whole hvac center you will be a god send.....
Old Jul 31, 2010 | 07:33 AM
O5_TRD_tC's Avatar
You have to get a complete unit, unless you find someone willing to sell just the screen.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
elzy0000
Jan 16, 2004 04:31 PM
