Turbo sizing
Old Oct 17, 2009 | 06:30 AM
ScionFred's Avatar
Default Turbo sizing
I'm looking for a new turbo and need some help choosing the best size for my app. I've found lots of compressor maps to help figure out the cold side but I haven't found much useful info on turbine wheel/housing sizing. I'm only looking for 200-250whp with fast spool on a stock block.
08 XB 2AZ-FE
Treadstone cast manifold
Tial 38mm wastegate, 7.25 lb spring, recirc. dump
2.5" downpipe, oem S-pipe, oem mid-pipe and cat, TRD axle-back.
2" charge piping to IC
2.5" charge piping from IC to TB
2.75" intake piping, 3" AEM dry-flow cone filter
Greddy Type S BOV (recirc)
AEM FIC, Boomslang harness
440cc Deatschwerks injectors
170F thermostat
NGK BKR7EIX
I'm thinking that a T3/T04B or E fits the bill but I'm not sure about whether to get a .48 or .63 A/R hot-side, stage 1 or 2 wheel. A .60 A/R compressor seems right but what trim? 40, 46, 50? It also seems like a little T3-60 trim might work well. Any advice is appreciated. TIA.
Old Oct 17, 2009 | 06:52 AM
Twilight2ner's Avatar
T3/T04E 50-trim
Good turbo and example:
http://www.atpturbo.com/mm5/merchant...egory_Code=TBN
Old Oct 17, 2009 | 07:00 AM
ScionFred's Avatar
Thanks. Nice turbo and the price is right but... I need a 5-bolt hot-side. Is .48 A/R big enough?
Old Oct 17, 2009 | 07:09 AM
.48 will spool fast, which you said you wanted. Look around on that site and others. There are some good options around that price.
Old Oct 17, 2009 | 07:28 AM
Ace83's Avatar
Ronin Scion
.48 a/r hotside will be good for you application
Old Oct 17, 2009 | 07:58 AM
jenn[tC]'s Avatar
+1. also if you want to help spool further, i suggest going with a full turbo back exhaust, keeping the stock midpipe and s pipe put some unwanted back pressure on the turbo.
Old Oct 17, 2009 | 12:58 PM
Prototype_xB's Avatar
If you are seriously only looking for 200-250whp your choice in wheel trim and a/r are irrelevant.
My experience--> t3/t04B .48a/r @ 8lbs (550cc+emanage, 10.5:1 afr) = 250whp/251wtq, 100% stock
any combo t3/t4 will give you what you want.
Old Oct 17, 2009 | 01:18 PM
ElevationTC's Avatar
10.5-1? why?
Old Oct 17, 2009 | 02:35 PM
Ace83's Avatar
Ronin Scion
10.5 is too rich, not good for the motor too
Old Oct 17, 2009 | 03:04 PM
cburglb34's Avatar
personally after 2 different turbos that had a .48 hotside ..i dont like it every freaking hill id go up id be spooling my turbo.....i feel much more relaxed with a .63 its full spools at 3k perfect for anything .48 was full spolled at like 2k im no fan but maybe thats what you want
Old Oct 17, 2009 | 03:10 PM
coryjames's Avatar
disco potato gt28rs
Old Oct 17, 2009 | 06:36 PM
ScionFred's Avatar
Thanks to everyone for your help. What do you think of Blaast Performance and this turbo?
GARRETT T3 / T04B "S" trim (130-350 HP)
TURBO SPECIFICATIONS:
compressor wheel: 48.4 / 69.9 mm 48 "S" Trim
compressor housing: 0.60 a/r T04B
center section: oil cooled journal bearings
Turbine wheel: 68 trim (stage1)
Turbine housing .48 a/r (.63 a/r upgrade available for 280+ HP)
Old Oct 17, 2009 | 06:47 PM
FromTheOld's Avatar
That "compressor map" doesn't tell anyone anything. It's not a real compressor map...look at the axes. It's just Blaast Performance's representation of what HP could be achieved, in their opinion.
Also, Blaast Performance has mixed reviews. Google the name, and find out what you can. Some love them, and some would not even step anywhere near them. I wouldn't step anywhere near them, but that's up to you.
EDIT: Removed the quote for less scrolling.
Old Oct 18, 2009 | 05:18 AM
ScionFred's Avatar
Yeah, Blaast took some liberties with that map. They must have assumed a VE figure, air temp and then changed the X-axis from airflow to HP. Still, that turbo should be very close to ideal for my app. As for Blaast Performance, I have no idea how good they are. I am 100% certain that a properly rebuilt Garrett turbo would be every bit as reliable as a new one but whether Blaast delivers that level of quality is unknown to me.
Old Oct 18, 2009 | 09:03 AM
Originally Posted by ElevationTC
10.5-1? why?
dezod preloaded map on Emanage. (Old S1 kit.) Just showing how whatever combo he goes with will reach his goal of 200-250whp. The 10.5:1 afr's were baseline's when i started tuning with dezod's basemap. Final product was 270ish whp, but beside the point.
Old Oct 18, 2009 | 04:36 PM
cburglb34's Avatar
whoa thanks for the info on blaast performance....i have a knock off t3/t4 to4e at home that can use a complete garrett rebuild for only 260
Old Oct 18, 2009 | 04:48 PM
rangerryda's Avatar
I like partial throttle boost Makes the car much peppier to drive around town where I do almost all of my driving. 48ar on stage 2 T3/T40E Turbonetics BB. It's almost like driving a supercharged car with the fast spool time. If you have a good tune, there is no reason to try to stay out of boost. On cruise control up hills, I don't hit boost.
Old Oct 18, 2009 | 05:54 PM
Ace83's Avatar
Ronin Scion
^^ haha gas will be terrible! but i dont care i love to hear spool.. i boost when i can.. on uphills as long you keep your foot light on the pedal you should just be boosting 0-2 psi
Old Oct 19, 2009 | 02:35 PM
rangerryda's Avatar
I boost 5 psi pretty regularly and still get 26-30 depending on highway or city. Max boost is 9 psi. With a log mani, 48 ar, and ball bearing, the thing spools really quick. No way around it unless you wanna drive like a granny!
Old Oct 19, 2009 | 03:09 PM
Brad i have a feeling your granny driving is my daily driving!
Ive never had a friend send me so many videos and pics of him maxing his speedo out LMAO!
