HELP slow acceleration under 4k rpm
Old Oct 19, 2009 | 06:28 PM
egscion's Avatar
Default HELP slow acceleration under 4k rpm
Hey guys, just noticed that when i hit the gas pedal there is a lag to accelerate anything under 4k rpm and after that it feels like the motor kicks in finally. i have 152k miles on my car regularly oil changed and regular maintenance with all the fluids. i did recently changed my tranny fluid. my thought is there may not be enough tranny fluid that is causing this delay when i accelerate. even when i go full throttle i can feel a lag. idk what the problem is. any suggestions?
Old Oct 19, 2009 | 06:45 PM
Jan06xB's Avatar
Spark Plugs???
Old Oct 19, 2009 | 07:12 PM
nodsetse's Avatar
^ Regular maintenance would call for plugs to be changed at 120k miles, so he should have already done that. IF not, then sure, time to change them.
Old Oct 19, 2009 | 07:44 PM
liltofuboix's Avatar
my guess was the sparkplugs as well. good luck
Old Oct 19, 2009 | 07:45 PM
beandip007's Avatar
did you clean the MAF sensor?
Old Oct 19, 2009 | 08:13 PM
egscion's Avatar
i'll change my spark plugs today after work. thx. i do remember changing them 20k miles ago and i'm sure i should have changed them again since. thx
egscion's Avatar
btw, shouldn't have anything to do with the tranny fluid either right?
Old Oct 19, 2009 | 09:24 PM
elcapetan's Avatar
I would say MAF or plugs... go clean the maf first... that doesnt fix it check your plugs
cburglb34's Avatar
lol nothing to do with trans fluid....but yea my money is on the plugs...unless ur runnign iridium(which last about 90k) then change ur plugs every other oil change....also a dirty maf could also cause this
Old Oct 20, 2009 | 06:14 AM
ColonelSanders85's Avatar
lol while you've got the hood up and are changing the plugs, you could also slap a decent turbo/intercooler setup on, that would also help the slow acceleration
Old Oct 20, 2009 | 06:30 AM
rangerryda's Avatar
Bad O2 in my book. MAF sensors don't usually get messed up unless tampered with. A little cleaning wouldn't hurt it but if it's as sluggish as he says it is, it is probably a faulty upstream O2.
Old Oct 20, 2009 | 12:45 PM
cburglb34's Avatar
but a faulty upstream would yeild a check engine....."when the light comes on, just come in......pepboys do everything for lesss LOL" song stuck n my head
Old Oct 20, 2009 | 04:11 PM
rangerryda's Avatar
A bad MAF would also throw a code. MAF Circuit - Voltage Too Low/High would pop up.
Old Oct 20, 2009 | 06:35 PM
cburglb34's Avatar
ive had 2 mafs take a crap on me one never threw any codes..
Old Oct 21, 2009 | 12:15 AM
Jan06xB's Avatar
Few things affect low speed performance other than plugs. With moderate throttle you can have low intake vacuum = heavy engine loading which can affect plug performance (misfires) more than a higher rev with lighter throttle. But checking the plugs will show you any other problems with combustion as well - fouling, incorrect gap, wear etc. so checking them first is usually a good idea. Next thing could be the VVTi timing of the valves being stuck, then less likely is A/F ratio which could be affected by the O2 sensor and the MAF sensor.
Old Oct 23, 2009 | 09:31 PM
egscion's Avatar
lol thx for the suggestions. no cel codes. just bought some new spark plugs today. gonna put em on after work. i'll let you guys know what's up. thx
Old Oct 23, 2009 | 09:42 PM
DMC0585's Avatar
Whats the best spark plugs and plug wires too use
Old Oct 23, 2009 | 11:15 PM
Jan06xB's Avatar
NGK Iridum plugs seem to be the plug with very good results. You don't have wires anymore - the coils are right on top of the plugs.
Check your old plugs for fouling and excessive gap as you take each one out and note if anything looks "funny" on them and what cylinder they came out of. You should also take a look at your tail pipe and see if anything is building up in it like soot or oil.
Old Oct 23, 2009 | 11:26 PM
engifineer's Avatar
If you changed them 20k ago then you should not have changed them since, especially if you used iridium like comes in the car. Those are recommended for change in 120,000 miles.
And a MAF sensor should be cleaned somewhat regularly. I clean mine every 2-3 oil changes. If they get cruddy, then performance can suffer, even without any codes being thrown.
Old Oct 24, 2009 | 01:33 AM
DMC0585's Avatar
Is there any better coils than the oem ones?
