Check Engine & VSC light on.. need some help
Old Oct 22, 2009 | 03:29 PM
yodjent's Avatar
Default Check Engine & VSC light on.. need some help
my check engine light and vsc light stayed on after i started my car yesterday. car runs fine, but the vsc & check engine light are on.
i have been running premium since i got it, but the last two fill ups i put 87 in it because i didn't see a different in gas mileage. I do do some minor towing with the vehicle, but always play it safe towing; i.e. take back roads to avoid highways, keep heater on to keep engine a bit cooler, etc. I also recently put on new winter tires on (firestone winterforce)
I am curious if you guys think it is the new gas i put in my car causing the lights to come on, or if it might be something more major..
like i said, the car runs fine. only reason im posting is because i have 52,000 miles on my car (08xb), and the dealership says my warranty is void.
Old Oct 22, 2009 | 03:55 PM
mnscionxb's Avatar
check to see if your gas cap in tight
Old Oct 22, 2009 | 03:59 PM
draxcaliber's Avatar
the dealership can't void your warranty, go to another dealership.
your 3year/36k mile bumper to bumper warranty has expired, but your 5 year/60k mile powertrain warranty is still in effect.
gas has nothing to do with it. running 87 octane is all you need to do unless you super or turbocharge the engine.
easiest solution, pull the CEL code, go to autozone or pepboys or wherever and have them pull the code out if you don't have a scangauge or similar tool.
Old Oct 22, 2009 | 04:02 PM
tc-guy's Avatar
we had a sienna come in that had those symtoms and it turned out to be one of the o2 sensors. not sayin that is what you have. just throwin it out there. i would check with another dealership cuz i believe powertrain warranty is 5 years/60000 miles.
Old Oct 22, 2009 | 04:42 PM
yodjent's Avatar
thanks for your help. i figured changing my gas had nothing to do with it, but having previously owned a fully built turbo car - you understand that there is a difference in how your car runs with premium versus 87,..
i will go get my codes checked 2day. i have to dj 2 weddings this weekend (fri & sat), so i am hoping my car gets me through this weekend with towing,.. (gigs only 5 miles away from my storage unit)..
i tried to find my paperwork for when i bought my car - looking into the warranty - and couldnt find any paperwork about the warranty... online said 60,000 miles, so im good..
im just hoping its something small.... only problem i ever had with my car, i had to replace the engine wiring harness (under warranty at time).. i love my xb, hate to have problems with it.
thanks again.
Old Oct 23, 2009 | 01:32 AM
yodjent's Avatar
update: just got the codes checked: it seems like a bad tank of gas. all the codes had the fuel system/gas in common.. im going 2 refuel 2mrw with premium, and hope the lights go away, otherwise- its to the dealership first thing monday.
Old Oct 23, 2009 | 01:57 AM
jnaval's Avatar
If filling it up with premium gas fixes the problem, then your car's like a high-maintenance girlfriend.
Old Oct 23, 2009 | 02:11 AM
do you fill it up from a top tier gas station, like shell, chevron, exxon, etc?
Old Oct 23, 2009 | 08:19 PM
yodjent's Avatar
i use Shell gas 99% of the time (right by my house). and when i use other gas (kwik trip, mobil, etc) i put only enough to get me to my shell gas station.
i put some premium shell gas in it today,, and my car died right away after starting it up.. F!, i cranked it some more and gave her some juice, she runs, although idles low (500ish)... im going to add some HEET to my tank, and see if that helps at all. cant really hurt it.
also when it in park and i rev it to a certain limit say 2000, it dips down then back up. and i dont move my foot. i did it several times and the same thing.. it only dips like 100-200 rpms. almost like there is a vacuum leak. but i dont know enough about cars..
Old Oct 24, 2009 | 01:43 AM
jnaval's Avatar
Actually, alot of xBs idle at around 500-600. I wouldn't be able to help you with the RPM dips but I'll just agree with you and say it's a leak. Where's the super techs to give an answer?
Old Oct 24, 2009 | 03:08 AM
ScionFred's Avatar
Sounds familiar. I had the same problem numerous times after refueling, especially on long road trips. The car would start and stall, and/or start and struggle to idle. It hasn't happened in several months now since I stopped topping off the tank. When the pump first shuts off, don't add any more. See if that helps.
The second issue is pretty normal for any new FI car. As long as the idle stabilizes after the first rpm dip, it's normal.
Old Oct 24, 2009 | 03:13 AM
RC-PILOT's Avatar
OK, first you only need regular gas, anything else is a waste of money unless your Turbo or Supercharged.
Second, you got codes pulled, but you didn't let us know what those codes were. That data can answer a lot of questions. If they all had something to do with an emissions leak, then you may need a gas cap, or other portion of the emission system replaced. Tests will pinpoint the cause.
Last, you would be suprised how many vehicles are repaired with a computer update. The computer is set up for a new vehicle, but as it ages, things change and new operational perameters that take in to account the wear and changes the vehicle has gone through can make it run better and also avoid a lot of engine light problems. ANY VEHICLE with an OBD2 system that has more than 50,000 miles on it, needs a computer update. I see it EVERY DAY in our shop. Powertrain warranty will not cover an update because it is needed due to "wear" over time.
Old Oct 26, 2009 | 04:09 PM
yodjent's Avatar
Default Engine Codes
The Autozone pulled 3 codes and here they are with their definitions.
P0441: Evaporative emission control system incorrect purge flow. probable cause: leak in EVAP system, Blocked EVAP purge line, faulty purge VSV.
p0455: Evaporative emission control system pressure leak detected - large leak. probable cause: faulty fuel cap, EVAP line leakage, pump module failure, canister faulty.
P0171: Air/Fuel mixture system lean bank 1 (cylinder number 1 denotes bank 1). probable cause: low fuel pressure, faulty MAF/VAF sensor, cylinder misfire condition, faulty h02s/AF sensor, large vacuum leak.
Let me know what you guys think is the culprit for my rngine troubles. like i said i "thought" is was the gas, but lights still on and almost went through a tank of premium without any major changes (car is running fine now, but lights still on).
thanks
Old Oct 26, 2009 | 04:48 PM
ScionFred's Avatar
You should either convince your dealer that your powertrain/emissions warranty is still in effect (because it is) or find another dealer.
Old Oct 26, 2009 | 06:16 PM
ImportCarSite's Avatar
With those codes it has nothing to do with the fuel your using it is an O2 sensor, vacuum leak or something like that. Whatever it is, it is covered by warranty take it directly to the dealership, if they give you some bs report them to Scion and take it to the next dealership. 60k warranty on engine and emmissions warranty should be longer not sure of exactly what scions emmissions warranty is but it should be longer than the drivetrain. Most cars are like 7 years 100k for emmissions warranties.
Old Oct 26, 2009 | 06:46 PM
mnscionxb's Avatar
did you reset your computer so the lights would go off?
Old Oct 26, 2009 | 06:57 PM
yodjent's Avatar
i did not reset the computer.... yet. dont know how. is that something i can do? or do i need to bring it in?
- i am trying to google the warranty info, so i have it in hand when i go to the dealership.
Old Oct 26, 2009 | 09:42 PM
Seriously if you can take it to a different dealer that dealer failed to know what they are doing I wouldn't risk taking my car to some dealer that is that ignorant.
It is on the scion website click car xB then warranty:
FOR THE LONG RUN.
There's nothing like a warranty for total peace of mind. Scion will back you up with these Limited Coverages:
BASIC COVERAGE
All components other than normal wear and maintenance items are covered for 36 months/36,000 miles.
POWERTRAIN COVERAGE
Your engine, transmission/transaxle, front-wheel drive, rear-wheel drive, seatbelts and air bags are covered for 5 years/60,000 miles. Rust-Through Coverage: Corrosion perforation of sheet metal is covered for 60 months/unlimited miles.
FEDERAL EMISSION COVERAGE
Components under the federal emission defect warranty are covered for 36 months/36,000 miles and specified major emission control components are covered for 8 years/80,000 miles. Specified major emission control components under emission performance warranty are also covered for 8 years/80,000 miles. In addition, emission performance warranty is applicable for 24 months/24,000 miles in states and local jurisdictions that require a periodic EPA-approved inspection and maintenance program.
TRANSPORTATION ASSISTANCE
You may be eligible for transportation assistance if your vehicle is required to be kept overnight for warrantable repairs. Please see your authorized Scion dealership for further details.
In addition, there may be times when we will establish a special policy adjustment that will further defray repair costs. For details about the new vehicle limited warranty, see your Scion dealer. And for complete details of Scion's warranties, please refer to your Owner's Warranty
Information booklet. [1]
CALIFORNIA EMISSION CONTROL COVERAGE
In California and any other state that adopts California emission warranty provisions, performance warranty and defect warranty coverage is applicable for 36 months/50,000 miles, and specific control devices are covered for 7 years/70,000 miles.
GENUINE SCION ACCESSORIES
Accessories installed at the time of the new vehicle purchase are covered for 36 months/36,000 miles, from the vehicle's in-service date, whichever occurs first, under the New Vehicle Limited Warranty. Accessories installed by the dealer after the new vehicle purchase are covered for 12 months, regardless of mileage, from the accessory installation date, or the remainder of the New Vehicle Limited Warranty, whichever provides greater coverage. Accessories purchased over-the-counter are covered for 12 months from the date of purchase. Car covers are warranted for 12 months from the purchase date and are not covered by the New Vehicle Limited Warranty.
EXTRA PIECES OF MIND
To give you extra peace of mind, Scion Solutions [2] has
developed vehicle protection programs that provide coverage beyond Scion's Limited Warranty. Visit us at Scion.com to learn about Extended Service Coverage, Guaranteed Auto Protection (GAP), Prepaid Maintenance, and Payment Protection.
Old Oct 27, 2009 | 02:32 PM
mnscionxb's Avatar
I think you can disconnect your battery for 15 min or so to rest it.
Old Oct 29, 2009 | 12:33 AM
yodjent's Avatar
my lights turned off finally.! i disconnected my battery overnight, and when i rehooked & started up the box... no Check Engine/VSC light!!!
f-yeah b!tches.
thanks everybody for your your help.
Jordly221
Feb 13, 2019 05:29 PM
Miqmiqmiq
Apr 16, 2016 02:34 AM
daniinpitt
Apr 4, 2015 08:07 PM
greytc
Jan 12, 2015 09:49 PM
AdmirN
Jan 5, 2015 10:19 PM
