How to remove dome and map lamp assemblies?
Old Oct 25, 2009 | 12:45 AM
TrevorS's Avatar
Default How to remove dome and map lamp assemblies?
I'm interested in replacing the overhead and cargo bulbs with LED versions, and it was pretty easy to pry out the cargo bulb assembly. However, when I tried to pry out the dome light assembly (near center ceiling), it showed no interest in letting go (got one side and end finger tip free, but the rest wouldn't come). Haven't tried the map light assembly yet.
Any hints on how to release them?
Thanks -- Trevor
Old Oct 25, 2009 | 12:49 AM
xtylerx's Avatar
There are little slots on the lenses that are just big enough for a small screwdriver. A little pry and they pop right out.
Old Oct 25, 2009 | 01:59 AM
Hannibal's Avatar
I just pulled and the whole assembly came out. You will feel like you are going to break it but you should be fine.
Old Oct 25, 2009 | 02:17 AM
TrevorS's Avatar
Slots, eh? Sounds good, I'll take a close look in daylight tomorrow.
That's exactly how I was feeling with the dome light assembly -- like I was practically hanging off it !
By the way, do six LED map light replacements and four LED dome and cargo replacements work well? They wouldn't be high power LEDs and I'm still trying to decide if cool white is better in the dome/cargo application than a natural or warm white . I'm guessing warm white might not be optimal.
Old Oct 25, 2009 | 04:08 AM
jnaval's Avatar
Kinda off-topic but is it me or does the dome light run really hot after, say, 10-15 minutes?
Old Oct 25, 2009 | 05:27 AM
CIONIDE's Avatar
Trevor, this thread has the links for 5 DIY videos that Captain ButterKnife made covering interior LED lighting swaps.
https://www.scionlife.com/forums/sho...d.php?t=173894
Old Oct 25, 2009 | 04:52 PM
TrevorS's Avatar
Well,as it turns out, your inputs applied to the map light, but not the dome light .
I found out the hard way the dome light is held in by four plastic hooks located two at each end and pointing outwards towards the sides of the car. Pulling until it feels like it's going to break resulted in exactly that -- one hook broke off.
Best guess looking at it is that you have to lever the assembly towards one car side far enough for those two hooks to release, lower that end far enough for them to clear, and then move the assembly in the opposite direction to free the last two hooks. I currently have the broken hook gluing, but doubt it'll be a great fix !
Old Oct 25, 2009 | 05:24 PM
TrevorS's Avatar
Ah, ha -- so, apparently the lens comes off pretty easily -- that would definitely have been a better solution for me than breaking a hook.
Thanks for the thread ! Now, if I can just figure out the best white temp to install .
horsefeathers
Sep 17, 2023 11:12 PM
jcsmamacita
Apr 7, 2015 06:04 PM
kleecker
Jan 9, 2015 02:26 PM
tc_Jake
Dec 31, 2014 01:45 AM
Opr8r
20
Feb 25, 2004 11:29 PM
