kaminari reverse cowl hood
Old Oct 26, 2009 | 11:10 PM
sciontC's Avatar
DeepSouth Scions
Default kaminari reverse cowl hood
soo..
http://www.kaminari.com/scion-tc-rev...od-full-carbon
Looking at this design, where does rain water drain? Does it just drop on the engine o.O Anyone with this hood or know care to chime in...?
Old Oct 26, 2009 | 11:30 PM
BZinn1's Avatar
well before the hoards tell you to search.......it falls between the radiator and the header.......nearly no water hits the motor at all.......I live in Washington state wehre it rains 300 days a year and run the hood year round and never an issue.
Old Oct 26, 2009 | 11:32 PM
sciontC's Avatar
DeepSouth Scions
hmm, awsome thanks
Old Oct 26, 2009 | 11:45 PM
sciontC's Avatar
DeepSouth Scions
Actually, one more question...what do I do with the wiper fluid wire being attatched to the hood? Im confused how to take this off properly?
Old Oct 27, 2009 | 12:02 AM
BZinn1's Avatar
That is the hardest part of the install......and it is easy.....on the hood there are dimples in the location of the washer nozzels.....
they get drilled out,use old holes in old hood for correct bit size,and use painters tape on hood before drilling to prevent and errors from bit moving.....
then a small file is used on each end to notch out for the nozzle clip,take your time and test fit a few times,then under side of hood also gets a 3/4" hole drilled in to let the nozzle fit cleanly,then reattach hose to hinge area using clip form old hood and shorten hose from nozzle to nozzle acordingly......
All in all it take about an hour to install......other than that it is an easy install.....
Old Oct 27, 2009 | 12:25 AM
GQQSE13's Avatar
brians the man and always has the answers and dont worry i've asked him the same question cuz i was worried the water would drip down by my CAI and would hydrolock
Old Oct 27, 2009 | 12:45 AM
SexyRS1's Avatar
If you car is parked and it rains some of the water does puddle up above the grill and when you go to drive it and you go above 40-50 mph the water will spray/sprinkle onto your winsheild. Not a big deal by any means but for about 2 weeks I was wondering how it was raining when it was 90 degrees and sunny lol. And i didnt drill through my hood for the washer sprayers, I think it looks cleaner w/out them
Old Oct 27, 2009 | 01:57 AM
SquallLHeart's Avatar
i would just not re-install the nozzles either.
Old Oct 27, 2009 | 02:23 AM
chicotunner07's Avatar
its ok for water to fall between the radiator and headers on an NA tc, but can you imagine water falling on a superheated turbo? im no rocket scientist, but i know that cant be good, lol
alot of F/I guys have very tight turbo/radiator clearance
Old Oct 27, 2009 | 02:49 AM
BZinn1's Avatar
I have always wondered if water on manifold would crack them quickly,I suppose it could,I had cast header on open fendered Buick and got a crack on it one winter....but never put the two together till years later.Pretty srue turbo manifold runs hotter than a V8 header does,which could be an issue.
Old Jan 10, 2010 | 09:32 AM
CLT-tc's Avatar
old post but does anyone have a s/c or turbo with this hood? i was looking for a hood to keep the engine bay cooler, but wouldnt even a few drops of rain fuse a heated s/c bearing to the shaft?
Old Jan 10, 2010 | 08:53 PM
GQQSE13's Avatar
i think a few have s/c's with them, not sure about turbos. i know if you have the dezod it wont work because of where the minifold is and the hood dips into the engine bay is
Old Jan 10, 2010 | 10:04 PM
gjpjr84's Avatar
i have this hood and supercharged, hadn't had an issue and its been like 2 years.
Old Jan 10, 2010 | 10:08 PM
Domo's Avatar
picking up this hood soon
Old Jan 21, 2010 | 06:28 AM
CLT-tc's Avatar
any more pics of this hood on FM?
Old Jan 21, 2010 | 11:50 PM
xdejablu3x's Avatar
yours is the fiberglass version right?
Old Jan 21, 2010 | 11:54 PM
draxcaliber's Avatar
i have this hood, and i've been supercharged and now turbocharged. no issues thus far.
Old Jan 22, 2010 | 02:05 AM
gjpjr84's Avatar
yea i have the fiberglass one. doubt there are any fitment differences between this one and the CF version.
Old Jan 22, 2010 | 02:44 AM
toeveryhour's Avatar
I have the hood and i am turbocharged, I don't think it is that big of an issue, like other people have stated.
Old Jan 23, 2010 | 05:36 PM
xdejablu3x's Avatar
i was thinking about buying that version myself cause i dont want the carbon fiber dealing with this texas heat. plus i park outside a lot and i dont really have time to keep waxing it.
