Transition AFR's
Old Oct 29, 2009 | 06:59 PM
THansenite's Avatar
Default Transition AFR's
I am looking to do some more tuning on my F/IC tonight and have a question about the AFR's. I know that when not in boost, they should be around 14.7 and at peak power, they should be at 12.5 to 12.3 depending on your boost levels. My question is about where they should be at partial boost.
I am running 7psi, so at around 3 or 4 pounds, where do I want my AFR's? Is it linear when I get into boost or should it get a lot richer as soon as the engine sees increased pressure?
Also, does it depend on the RPM's of the engine? At 3psi, should it be slightly leaner at low RPM's and richer at high RPM's or doesn't that matter?
There isn't a lot of info out there on partial boost tuning. I know that the best way to find out these answers is testing it on a dyno, but I'd like to get a halfway close street tune before buying dyno time.
Old Oct 29, 2009 | 07:09 PM
ElevationTC's Avatar
well it needs to tranistion
I tune for 14.7-15.0 cruising
Part throttle 12.6-13
WOT 11.5
Old Oct 29, 2009 | 07:23 PM
THansenite's Avatar
Care to elaborate a little more?
Is it dependant on RPM's at all or just boost pressure?
Is it a linear transition?
assuming the following:
@0psi - 14.7
@7psi - 11.7
does that mean 3.5psi should be exactly in the middle?
ie. (14.7+11.5)/2 = 13.1 @ 3.5psi?
Old Oct 29, 2009 | 08:18 PM
Ace83's Avatar
Ronin Scion
I tune mostly on manifold pressure more than throttle position.. i could be in partial throttle but reach full boost or part throttle and not hit boost at all.
Cruise
0-5inHg 13.0-13.4
5-10inHg 13.4-14
10-14inHg 14.4-14.6
14-22inHg 14.4-14.8
Boost
1-3 psi 12.6-12 afr
4-6 psi 12-11.8
7-9 psi 11.7 afr
10-11psi 11.5
Old Oct 29, 2009 | 09:45 PM
coryjames's Avatar
wot 11.8-12.2 E85
coming up on 0-5 hg i tune to 13.5
and normal idle and cruise at 14.7
for a conserve tune
on mine
up to 0-4 psi 13.5-14
4-8 12.8-13.2
8-14 12-12.4
and idle 14.7 and anything in vacuum
Old Oct 29, 2009 | 10:28 PM
t_urbo_C_harged's Avatar
That E85 is some good ish!
Old Oct 29, 2009 | 11:05 PM
Ace83's Avatar
Ronin Scion
^^ sure is.. my e85 tune are also 11.8-12 WOT, slightly leaner on low boost and vacuum than my 93 oct tune
Old Oct 30, 2009 | 02:17 PM
THansenite's Avatar
Thanks guys. That helps me out a lot. :up: Hopefully, I'll get a decent tune on the car and take it to the dyno soon. Then, it will be ready for even more boost hopefully.
Old Oct 30, 2009 | 02:25 PM
Ace83's Avatar
Ronin Scion
do tons of datalogs, get it as close as you can so you wont spend too much time on the dyno.. unless they will give you a flat rate then do everything on the dyno
Luisfc1972
Aug 29, 2015 02:30 AM
rancur3p1c
Jul 12, 2015 07:59 PM
Joe_Dezod
152
May 23, 2013 08:59 PM
Joe_Dezod
45
Aug 24, 2008 12:39 AM
sohc_mshue
25
Aug 29, 2006 12:46 AM
