What gap should I be on with a turbo TC?
Old Nov 2, 2009 | 12:57 AM
16G-Scion's Avatar
Default What gap should I be on with a turbo TC?
I'm getting random misfires back and forth with sluggish accelaration/boost and I even cleaned the MAF with MAF cleaner.
Any Ideas??
I've ran searches back and forth on this..nothing
Old Nov 2, 2009 | 01:04 AM
Ace83's Avatar
Ronin Scion
new issue? or new setup.. it could be a lot of things.. tuning is usually the biggest part
Old Nov 2, 2009 | 01:06 AM
16G-Scion's Avatar
I think it could be a bad tune too...is a .028 gap good for cold plugs?
new issue btw...
Old Nov 2, 2009 | 01:38 AM
m6ar2cel6oTC's Avatar
I run .32 on 20psi. On 2 step colder plugs. It probably is the tune. Are those plugs different gap from the ones that the the was on?
Old Nov 2, 2009 | 01:42 AM
Prototype_xB's Avatar
between .028 and .030 is good
NGK Iridium cold plugs are pre-gapped at .030
Old Nov 2, 2009 | 01:50 AM
16G-Scion's Avatar
I'm using BKR7EIX-11, 6988 with a .028 gap on 8psi..
my car was tuned by Japtrix in Palm Beach..
Old Nov 2, 2009 | 02:37 AM
Ace83's Avatar
Ronin Scion
that like the ngk 1 step colder, that gap is fine.. more of tuning issue. its been like that since they tuned it?
Old Nov 2, 2009 | 02:41 AM
16G-Scion's Avatar
Yes...
It ran better on the regular AEM Base Map! LOL!
I also spoke to Luiggi from Olympic Motorsports who wanted me to download my map and send it to him via e-mail. Unfortunately, I don't have the slightest idea on how to do that..hehe
Old Nov 2, 2009 | 02:42 AM
with the random misfires are you getting any knock sensor feedback? Maybe you have too much or not enough timing advance
Old Nov 2, 2009 | 02:44 AM
16G-Scion's Avatar
You mean like CELs? Sorry i'm a tuning noob..hehe
Old Nov 2, 2009 | 02:52 AM
cburglb34's Avatar
are u getting any check engine lights? or does it just feel like its missing
Old Nov 2, 2009 | 03:01 AM
16G-Scion's Avatar
I'm getting the random misfire CELs...threw for all cylinders...
Old Nov 2, 2009 | 03:11 AM
cburglb34's Avatar
hmmm thats odd, doesnt hurt to increase gap to .30 though and when was the last time u changed the plug cuz coppers only last like every other oil change at most
Old Nov 2, 2009 | 03:15 AM
16G-Scion's Avatar
changed them yesterday...actually
Old Nov 2, 2009 | 03:32 AM
Ace83's Avatar
Ronin Scion
i suggest taking it to a better tuner or you can learn how to tune and tune it yourself
Old Nov 2, 2009 | 03:55 AM
thendawg's Avatar
I 2nd that - deff a tuning issue - also hes not using copper plugs the EIX indicates its the NGK Iridium IX which is a very nice plug - im running the exact same plug as it came which is gapped to .030 and ive had 0 issues with mine (Im using the 7 also which is one step colder)
Old Nov 2, 2009 | 03:59 AM
Ace83's Avatar
Ronin Scion
and i dont think its a spark plug gap issue either. What situation do you miss? cruise, part throttle boost or at WOT
Old Nov 2, 2009 | 04:01 AM
Yes, CEL's. Sounds like ignition timing. Call up your tuner and ask them if they adjusted ignition timing. You say it ran better on the base map. So if they changed that then this could be the problem. You just changed ur plugs, so was this happening before you changed ur plugs?
Old Nov 2, 2009 | 04:06 AM
bro take it back to japtrix. which honestly is not a good place for a scion. 07tcryder (olindo) took his car there and they messed it up there. i heard not so good things about them. but anyways try the gap to .30 and before you changed the plugs did it misfire also? try changing the coilpacks around. and see if you get random misfire. but if its not the gapping then for sure its tuning? when does it misfire on partia throttle or WOT?
Old Nov 2, 2009 | 04:12 AM
What AFR's are you seeing. I ask this because i fouled a set myself in 1 day....haha
10.5:1 during early stages of tuning. After bogging and misfires, we changed and ran great.
