Torque Dampers are they worth it?
Old Nov 4, 2009 | 01:16 AM
jcXB's Avatar
Default Torque Dampers are they worth it?
Weapon R or Ingalls stiffy for xB1. Any one have it? Opinions? Reviews? I use my xB as a daily driver and I don't race or anything.
Old Nov 4, 2009 | 03:08 AM
liltofuboix's Avatar
^ not really. unless you have turbo or your car has alot of torque. I really doubt it. and it also causes alot of interior noise you don't want. in addition its basically a car show piece if anything
Old Nov 4, 2009 | 04:21 AM
drewskie14's Avatar
I did it to my tC and I noticed it just about got rid of skipping during starts when spinning the tires. Other than that it does create interior noise as a side effect... Really not worth the price imo
Old Nov 4, 2009 | 08:50 AM
bB384's Avatar
IV ACE
I would rather invest the money in getting better motor mounts. But as you stated you don't race so it wouldn't be worth it since with either the mounts or damper you're going to get vibration and noise.
Old Nov 4, 2009 | 01:03 PM
Black_Sheep_xB's Avatar
Your stock motor rocks pretty good at a hard launch, there is a noticeable change after installing the damper.. especially in a manual trans. I think it's a must if your into hard launches, and motor mounts wouldn't be a bad investment either.. but with just the damper, the motor barely moves.
Old Nov 4, 2009 | 03:50 PM
jcXB's Avatar
Thanks for all of your input. I definitely don't do launches so this probably wouldn't be worth it. I'm going to invest the money in the progress rear sway bar instead. I read some really positive reviews about them. Thanks everyone!
Old Nov 4, 2009 | 03:51 PM
burstaneurysm's Avatar
They do make a noticeable difference. PM'd too.
Old Nov 5, 2009 | 04:06 PM
Malibuguy's Avatar
i mixed about mine, i just installed an Ingalls 2 Tuesdays ago...it didn't get rid of my wheelhop issue...
Old Nov 5, 2009 | 04:24 PM
maybe you have another issue causing it.. like a loose/broken mount somewhere. I had wheel hop before the ingalls, and not after personally.
Old Nov 5, 2009 | 09:18 PM
Malibuguy's Avatar
the car has 42K on it...that may be possible...does anybody make stiffer mounts? I know i can get the trans mount done...its the same as my Tercel trans mount, but the rest of the mounts are different...
Old Nov 5, 2009 | 09:28 PM
Jan06xB's Avatar
You get wheel hop when you dump the clutch too quick and break the wheels loose - then they get hot and grab then slip and get hot and grab back and forth making it hop and the engine mounts winding up a little makes it worse. Try slipping the clutch a little more smoothly . . . I get launches at about 3k rpm that really pull without any tire slippage going straight that surprise me sometimes and the car behind me as it disapears in the rear view mirror.
What I do have problems with is on damp days after a rain my clutch will chatter and buck like crazy with little or no gas as I let it out and I end up taking off in 2nd gear and slipping it a lot to dry out the clutch. At the same time the brakes make the front end nose dive with the slightest pressure until they dry out too.
Old Nov 6, 2009 | 02:17 AM
Originally Posted by Malibuguy
does anybody make stiffer mounts?..
Energy has a kit.. all the mounts (inserts) for like 45-50 shipped
Old Nov 6, 2009 | 02:28 AM
jct's Avatar
jct
no mad wheel hop with it installed nuff said
Old Nov 6, 2009 | 11:46 AM
Malibuguy's Avatar
i tried looking on their site a few weeks ago...they only list stuff for the tC
Old Nov 6, 2009 | 03:07 PM
http://www.dezod.com/pd-energy.cfm
and they have them on ebay too.
Old Nov 6, 2009 | 04:57 PM
Malibuguy's Avatar
thanks...i'm going to buy those in a couple weeks
Old Nov 21, 2009 | 05:10 AM
SXT_HuntToKill's Avatar
DelMarVa
wheel hope can also be caused by bad struts and sway bar linkage and bushings if worn... struts usually not to be checked and or replaced if needed every 60k-70k... im talking factory to not trd... linkage on my swaybars went bad at 30k replaced em with pollys from autozone $10 for universal kit fits perfect and $20 for the ubolt bushings also universal... work perfect...
Old Dec 1, 2009 | 01:53 PM
Giupo's Avatar
I have tried the Energy Suspension mount insert in my car but the noise and vibrations are very unbearable! I have removed them immediately.
The Ingalls or Weapon R engine dumper produce the same effects?
Old Dec 1, 2009 | 02:52 PM
jct's Avatar
jct
they do... but you can adjust the damper so they don't vibrate into the cab
Old Dec 1, 2009 | 04:19 PM
Malibuguy's Avatar
my ingalls transfered noise (even with the suggested dynamat on it), but not any real noticeable extra vibration even at full tight...its for sale if anyone wants it, it maybe has 3 weeks of driving on it max
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
BlingSlade
Oct 19, 2016 12:39 AM
Klunkerbill
Nov 9, 2015 11:39 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
JonathonK
Sep 22, 2015 07:27 PM
