2004-2006.5 [NCP61]
clutch chatter
Old Nov 6, 2009 | 06:08 PM
bwe's Avatar
bwe
Default clutch chatter
My Xa has a bit of clutch chatter at the start of the day, but then it goes away. Is this common?
Thanks!
Old Nov 6, 2009 | 06:19 PM
Gmonroe80's Avatar
What do you mean clutch chatter? squeaking? grinding? Sounds like people talking?
Old Nov 6, 2009 | 07:11 PM
bwe's Avatar
bwe
I feel vibration in the pedal the first couple of times I engage the clutch, after that it's fine.
Old Dec 16, 2009 | 03:52 AM
SatsumaxA's Avatar
Mine "clatters" when sitting idle in neutral/clutch released.....goes away when clutch is pressed.... Also louder w/ AC on. Has been continual for last 50K miles... no problem - think throwout is chattering on fork??
Old Dec 18, 2009 | 03:37 PM
DeiselFuel2o2's Avatar
Perfectly normal!
Cold temperatures hinder the the grabbing power of the clutch so it will chatter (heat itself up) until it is warm, then once it is warm the materials are sticky again
If it happens non-stop, you might be do for a readjusting or you need some clutch fluid.
Clutches go bad when they slip.
Drive on!
Old Dec 18, 2009 | 04:52 PM
jct's Avatar
jct
the throw out bearing uses the same brake fluid from the master cylinder...
a23r
Feb 1, 2016 04:05 AM
ericr64
Nov 14, 2015 04:52 PM
carbinefreak
Sep 24, 2015 02:06 AM
Mjdavis1994
Sep 21, 2015 04:42 AM
scionsux
Sep 2, 2015 05:30 AM
