eksDeviant
11-08-2009, 07:42 PM
I'm trying to remove my rotors but I have no idea what size axle nut I need... Anyone have any clue?
View Full Version : What size axle nut do I need to remove my rotors? eksDeviant 11-08-2009, 07:42 PM I'm trying to remove my rotors but I have no idea what size axle nut I need... Anyone have any clue? helloninja 11-08-2009, 10:57 PM No need to remove any axel nut.... There is a full DIY in here somewhere... but you just have to remove whell and brake then rotor will pull off...it my be stuck so get a screw and there is a little hole near the hub, insert screw and it will hel emensly... Good luck DeathMachine 11-09-2009, 03:14 AM Exactly!! You shouldn't have to remove the axle nut for anything unless you are replacing parts of the steering/hub system... uskrewed 11-10-2009, 06:12 PM I'd highly recommend you taking your car to a real mechanic to get any work done. johnhawkins 12-29-2009, 07:59 PM What is the size of the axle nut though? I need to know so I can pull my tranny....one post stated it was a 32mm Deep 12 point but that is too large and I need to order one that fits. cingham 01-16-2010, 06:45 PM ITS A 30MM 12 PT SEARS 8.99 there no one ever has to look for that bit of info again johnhawkins 01-19-2010, 08:37 PM thank you so much man! |
