vitalyze
11-08-2009, 10:36 PM
Does anyone know if trd makes some sort if shield for the air filter? Or can I get a hydrishield that injen makes and put it over the trd filter? I'm not sure if those are brand specific.
Thanks
Thanks
View Full Version : Cai qquestion vitalyze 11-08-2009, 10:36 PM Does anyone know if trd makes some sort if shield for the air filter? Or can I get a hydrishield that injen makes and put it over the trd filter? I'm not sure if those are brand specific. Thanks GQQSE13 11-08-2009, 10:42 PM the trd comes with a piece that basically does the same thing, goes on where the 2 pipes connect 203superwhitetC 11-08-2009, 11:18 PM yea just get the TRD if you're THAT worried about hydrolock. it'll give you piece of mind lol killatc171 11-08-2009, 11:19 PM yea the trd comes with the aem bypass valves which pretty much does the same thing. incase the filter is in water, the bypass filter will do the same thing. so you should be good. no need for anything else. but you shouldnt have a issue even with rain unless you front end and filter are completley under water. vitalyze 11-08-2009, 11:41 PM Is that sponge thing the water bypass valve? GQQSE13 11-08-2009, 11:55 PM ^^yep |
