difference in 2 psi
Old Nov 10, 2009 | 10:18 PM
cburglb34's Avatar
Default difference in 2 psi
WOW lol so my afr were in low 11's with my safc set to +38% on 410cc injectors with a to4e on 4psi
i decided to change my wastegate source to the brake booster to get 6psi and WOW i maxed my SAFC at +50% and it was at 12.9 afr and PULLING like a frieght train man if only i had bigger injectors so i could leave it at 6psi
Old Nov 10, 2009 | 10:19 PM
cburglb34's Avatar
BTW changing vac source to brake booster makes boost come in HARD and FAST compared to compressor housing but doesnt control boost as well as the housing would
Old Nov 10, 2009 | 10:28 PM
ElevationTC's Avatar
6psi like a freight train..
you would ____ ur self if you rode in a 400whp tc lol!
Old Nov 10, 2009 | 10:29 PM
SoFloTC's Avatar
^ haha for real!!!
Old Nov 10, 2009 | 10:36 PM
Chad, were going to need one more coupler now! Do you have any at your house?
go on face book!
Old Nov 10, 2009 | 10:44 PM
thendawg's Avatar
Yea you def arent maxing out the injectors - im running the same injectors at 7psi on a T3/T61 - making 7.2-7.5 psi according to fic datalogs - and i have no problem maintaining 11.2-11.5 afr under full boost all the way to redline. Also on my original more conservative map it was hitting as rich as 10.3 under full boost (still 7 psi) - i had to lean it up a bit to get the afr more where i wanted it (11.2-11.7). Ive tested the current map down to around 45F outside and it runs great with a constant well maintained afr. Maybe the SAFC is the restriction?
Old Nov 10, 2009 | 10:46 PM
thendawg's Avatar
Also forgot to mention - i know this will affect afr - im pulling 3.5 deg of timing at peak tq - leveling off to -2.5 deg at redline - i dont think the safc can pull timing so that may be some of the issue.
Old Nov 10, 2009 | 10:52 PM
ScionFred's Avatar
I think a manual boost controller tapped off the comp housing might help. You could dial in 5psi or whatever boost your injectors or SAFC can handle. Also a minor point but I believe you actually have a T04B comp.
Old Nov 10, 2009 | 11:08 PM
cburglb34's Avatar
lol i mean ive been in much higher hp cars but to drive on is a different story....
yea i think your right might be a B housing
Old Nov 10, 2009 | 11:09 PM
cburglb34's Avatar
yea its the SAFC thats restricting me because you can only tune the maf signal and well im maxing it out at + 50
Old Nov 10, 2009 | 11:44 PM
thendawg's Avatar
Ahh i forgot - thats why i love the fic - it directly adjusts the injector pulsewidths by interrupting the signal to the injectors. I think the maf maxes out at like 5v - so you can only add so much fuel using the safc or any other device that tunes by increasing maf voltage.
Old Nov 10, 2009 | 11:50 PM
cburglb34's Avatar
yea it sucks...oh well i can always sell it and buy a fic or i can just go buy 440 injectors and make the safc happy
Old Nov 11, 2009 | 12:10 AM
gingles's Avatar
i thought it wasnt a good idea to tap into the brake booster for your wastegate vac.
Old Nov 11, 2009 | 12:12 AM
cburglb34's Avatar
read what i said earlier i said that the compressor is better because if u tap from the manifold/brakebooster it doesnt control boost aswell
Old Nov 11, 2009 | 12:22 AM
gingles's Avatar
i read that...but am wondering why you would even do it
Old Nov 11, 2009 | 12:24 AM
cburglb34's Avatar
because its the way most people do it its really personally prefference, brake booster gives u exact wastegate pressure, makes boost come in faster and HARDER, but tends to sometimes spike
but when u have the compressor housing u dont have spike and boost is more even controlled, and if your IC piping is long and you have a big frount mount u could drop 1-2psi off ur wastegate pressure
Old Nov 11, 2009 | 12:52 AM
thendawg's Avatar
Mines t'd off with the rest of my vacuum lines - including fic, guage, and bov - ive never had a problem with spikes although apparently some have. I only did it because my turbo compressor hadnt previousely been tapped when i got it and i didnt feel like taking the time to tap it lol I might sell my fic soon - when i go to manual swap im really wanting a standalone - i wanna rev to like 7k - hey on that note - does anyone know if you can up the redline to 7k by simply going with upgraded valve springs and retainers (no cams or valves). I know dezod sells the bc spring and retainer kit for like $280.
Old Nov 11, 2009 | 12:54 AM
B_Real45's Avatar
2psi gain with that vac source change means your intercooler is very restrictive - or something between the turbo and intake manifold is causing a restriction.
Some people gain 1psi at the most.
Old Nov 11, 2009 | 01:01 AM
ScionFred's Avatar
The easiest way to know is to look at the clamps that hold the comp housing to the back plate. 3x 2 bolt = T04B, 2x 3 bolt clamps = T04E.
My CXR chinacharger has "T04E" stamped right on the comp housing but it's really a T04B.
Old Nov 11, 2009 | 01:31 AM
thendawg's Avatar
Lmao @ chinacharger
