View Full Version : The Offset Calculator
BlkTC
11-11-2009, 11:10 PM
i don't know if this has been double posted, but someone should sticky this..
http://www.1010tires.com/WheelOffsetCalculator.asp
if you don't know how to use this, just adjust the numbers to your liking to see the fitment change between the wheels you are comparing to.
stock size is 17x7 et 45 (i think)
so yeah... this is VERY helpful..
B Real45 wanted to contribute, so here's another link to one where you can try tire sizes.. BUT!! it doesn't let you stretch tires.. lol
http://www.rims-n-tires.com/rt_specs.jsp
ANNNNNNNNNNNNNNNNNNNNNND now you can calculate tire sizes
http://www.1010tires.com/TireSizeCalculator.asp
fiendskillz
11-11-2009, 11:28 PM
lol says my new wheel specs gonna be 57mm out from stock (fronts)
BlkTC
11-11-2009, 11:35 PM
hahaha SICK!! that's what it should be.. lol
mine is 63 mm.. haha
BlkTC
11-11-2009, 11:37 PM
after a 15 mil spacer in the rear..
17x10 +20 :DDDD
heroine_bob
11-12-2009, 02:36 AM
i thought it was stickeyed before... but i guess not.
it was put in the tech articles a long time ago. keaons wheel tips.
http://scionlife.com/forums/showthread.php?p=668002#post668002 (http://scionlife.com/forums/showthread.php?p=668002#post668002)
but i agree that calculator should be stickeyed
use it all the time too
o8tC
11-12-2009, 05:18 AM
if i order mine they will be 63mm lol
BlkTC
11-12-2009, 08:02 AM
dayuumm.. SCION scene steppin their game up sick-like!
BlkTC
11-13-2009, 07:54 AM
bump for sticky.. :D
Aroddalobster
11-14-2009, 10:50 PM
man up and memorize 1 in = 25.4 mm like a normal person lol
B_Real45
11-15-2009, 05:00 AM
Best calculator:
BlkTC
11-15-2009, 11:18 AM
lmao.. that's lame.. i tried stretching a 215/40 on a 10, and it keeps altering the width.. hahaha
Domo
11-15-2009, 11:19 AM
sticky icky
B_Real45
11-15-2009, 12:35 PM
Because you can't fit 215 on a 10" wide rim... how's that lame?
BlkTC
11-16-2009, 05:26 AM
i just wanted to see how stretched it would be if i put a 215/40/17 tire on a 17x10 wheel.. lol..
but since you don't understand why i said that.. i'll put your link into the first post as part of the sticky icky.. :D
Jon
11-29-2009, 12:13 AM
Anyone know the clearance from the stock wheel to the strut? Using the calculator, the set up I want will be 20mm closer to the strut and sit 30mm further out.
*Thread Stickied*
BlkTC
12-26-2009, 05:07 AM
im not sure at all, but for the rear, my 17x10 +35 hit the A arm.. i needed a 15mm spacer in order to clear it.. but that's for my height..
for the fronts, my 18x8.5 +25 was pretty damn close to my B+G strut.. maybe off by 20mm.. but that's just with my B+G coils..
06tcdude
02-11-2010, 10:52 PM
Ok I'm not good at all the jdm flush and poke etc. So if I have 17x7 et 40 wheels, how much spacer do I need to flush rear?
Aroddalobster
02-12-2010, 01:19 AM
over 25mm, so i wouldn't try.
06tcdude
02-12-2010, 01:54 AM
Dang. So how are people flushing stock wheels with 8mm spacers? Or are they not?
BlkTC
02-12-2010, 05:02 AM
i didn't know ppl were.. but you would need WAY more than 8mm to fix the fitment of stock wheels.
i needed a 15mm on my 10 et35.. with the 15mm i barely got a decent amount of poke that i was able to camber into the car.
Aroddalobster
02-12-2010, 08:32 AM
if they are, it's because their wheels are way more flush to start out with. your specs are only a 5mm difference from stock. I'm not even flush at all, and i'm 12.7+5, so 17.7mm more aggressive than 17x7 +40, (i'm 17x8 +35). from where I am, i'd need 10-15mm spacers to actually be flush, which results in an ultimate spacing of 32.7mm for you, which i would not recommend at all.
wider and lower offset will get you a better platform for you to jump on the herrafrush bandwagon.
06tcdude
02-12-2010, 06:26 PM
well on hotchkis, and my sound system, i would rub, and i cant afford tires all the time, so camber is a no-no
Un4Scene
10-11-2010, 10:55 PM
The link to the calculator for tires doesn't seem to be working. Does anybody know of another one that's usable?
Jon
10-11-2010, 10:56 PM
I think the first link has a tire calc. also.
Edit: Yeah it does. http://www.1010tires.com/TireSizeCalculator.asp
Un4Scene
10-11-2010, 11:03 PM
Wow... I totally missed that. That's what I was looking for. Thanks!
BlkTC
10-12-2010, 09:16 AM
now in OP
sebascolombia91
01-19-2012, 11:48 PM
Very helpful.
