Audio Question!
Whats the best amp to power 2 12" W3s (D-6)...I'm trying to decide what the best amp is. I was thinking a 1200W of some kind but not sure...Could use some help or advice...Thanks!
Thanks...didn't know there was one
HAHAha just messing with you Manny
Well I hope Dr. Phil can help me decide what kind of amp I should get to power my new subs...how bout we get back to the real issue at hand here...i dont think anyone here is having emotional problems so no need for Phil
Well, let's see where do I begin . . . You may consider your friend "hooking" you up with just problems. Those are Dual 6ohm Coiled subs. Unless you find an amp that will run 1.5 ohms stable, or sacrifice lots of power runing those things at 6ohms you better get the dual 4's or dual 2's ohm. Another solution to properly running the subs would be getting a third jl sub at 6ohm, which will allow you to run 4ohms or 1ohms. If not then you will be running dirty power that will be variable and not at all what the amps were intended to do. This is a gernalization. say you keep the two subs as is. This is not exact math or anything that may apply universally, but you have a 1000watt amp at 4 ohms. you run those subs at 6ohms. The actual power you will recieve would be approx 660 wats, not 1000, since the ohm ratting is higher. 6ohm's is more for 3 subs applications, that's all I'm trying to let you know about. Good luck! Try www.zapco.com , www.lunaramplifiers.com , www.usamps.com , http://www.cbrstereo.com/index.asp?P...OD&ProdID=1012 For amps.
get another w3 and get an ED Nine.1 www.edesignaudio.com great amps warranteed. $350 for 1200 watts at 13.5 volts, which means at minimum 1200 watts. Great look, great amps.
hifonics 1500d or 1000d are both good also, i own the 1500 and like it. it is a budget amp, however.
even if you don't get a third w3 then the nine.1 is still a solid amp with a three year warantee. and sexy too
Well it looks like either the Hifonics 1000w or 500/1 JL...would the Hifonics be a good one to split 2 subs on? The JL would be nice but are kinda expensive...still looking for a cheap one
bootlgr
Jan 26, 2016 01:22 AM
