Removing 05 tC hatch shocks
Old Nov 19, 2009 | 09:28 PM
Kvizzel's Avatar
Default Removing 05 tC hatch shocks
I think there called hatch shocks struts whatever.
Is there a DIY on how to remove them and install them?
Old Nov 20, 2009 | 03:17 PM
ibidu1's Avatar
Its very very easy! Open the hatch, have a friend hold up the hatch. Grab a small flat head screwdriver. On each shock you have two metal tabs on each end. Slip that screw driver under the metal tab as if you want to pry it from the shock. The one side of the shock should jiggle right off, and you would do the same for the other side. You have 4 clips in total to pry off.
Old Nov 20, 2009 | 04:23 PM
Kvizzel's Avatar
Okay thanks, i looked and i do see these metal clips.
I pulled them out, but the shocks aren't moving. Should i just rip them out?
Old Nov 20, 2009 | 11:33 PM
Kvizzel's Avatar
Okay got em!
All i did was wiggle and twist the shocks till they came out.
Thanks!
webekyle
Feb 7, 2015 07:15 AM
kleecker
Jan 9, 2015 02:26 PM
swtbabiboi4u
Feb 1, 2004 02:35 AM
swtbabiboi4u
Oct 13, 2003 04:38 PM
swtbabiboi4u
Oct 10, 2003 01:40 AM
